deb
- Joined
- Aug 1, 2002
- Location
- Sebastopol, CA
Hello,
My A/C is not working all of the time. It seems that when it is really hot it won't come on and as the car cools a bit it works. I found a thread that talks about a similar issue on a newer Passat. They mentioned that a bad relay was probably the cause. I am thinking that I may have the same issue. Where are the A/C temp control relays in my car? Or, are there any suggestions as to what the problem might be? I have ruled out low freon because when the A/C works it is good and cold.
Thanks,
Deb
Thanks,
Deb
