2.0 pistons: Aftermarket vs OEM
Scufi
United Kingdom
2.0TDi 170
I am trying to setup a new engine configuration based on all the data I can gather.
The things that interest me on this comparison are:
1. Piston mass
2. Bowl shape
3. Material
4. Ceramic coating easiness
5. Lowering compression ratio by machining bowl or whole piston
Scufi
United Kingdom
2.0TDi 170
I will start and address point 5.
By choosing OEM I can have the following:
1. 2.0 PD piston: 18.5 static compression
2. 2.0 CR piston: 16.5 static compression
My target is 16 static or lower.
To obtain this target with PD pistons the bowl will be enlarged too much. The OEM crown cannot be shaved to obtain lower ratios. Custom pistons might be.
Bowl shape and pip will affect combustion. Please view the following.
This is copyrighted material so any reproduction will be considered a violation of applicable laws.
Representation is done at maximum engine power.
Representation is done to compare maximum engine torque.
IP stands for Injector Protrusion and is measured in mm.
Whitbread
Vendor , w/Business number
Johannesburg, MI
Several
The only way you're going get below a 16:1 static ratio without custom machining is to use the Diamond forged aluminum pistons. However, don't expect much over 40-50K miles before the ring lands get worn out as cummins and duramax guys have found out.
http://www.mooregoodink.com/news/?p=1777
Scufi
United Kingdom
2.0TDi 170
Yes. The CR pistons are a viable option. Low dead space volume, low compression ratio.
Hard to source. Expensive at dealership.
The diamond pistons may last longer on moderate driven TDIs.
For a competition car, 50K is more than 1 season. Much more.
Is there a weight difference between OEM and Aftermarket con-rods ?
A low weight but stronger combination of con-rods and pistons might put a smile on my face.
