danski0224
My mileage has gone from bad to worse, last tank figured out to just under 10 mpg. It is rated at 16 city. I do not idle it to warm up.
Less than 4k miles on the van, purchased at the end of August.
Is it possible that my drive is too short? It is only 4 miles each way to work now. I suspect that it doesn't get warm enough for the ECU to switch into closed loop mode.
My last jobsite was 9 miles each way, and the mpg was better at 15.
Engine, trans and diff are filled with Amsoil.
Any ideas?
Any ideas?
