May-39
Should N18 hold vacuum?
With regards to N18
The line feeding the VAC (top nipple) is providing 28 inches per Mityvac.
N18 WILL NOT hold vacuum
I pulled it off and tested both ports...I would run it up to 20 inches and it just slides right back to zero.
N75 and N239 held vacuum.
PROBLEM THAT GOT ME HERE:
Low power/ boost when car has been running 15-20 minutes.
When car is cool, runs like a champ, boost climbs steady to 15-16 pounds no spikes or jumps.
When been run awhile, boost wont go over 6...
Turbo and actuator (newer) pass bench test, actuator works great, vanes move freely.
Borrowed MAF from pals great running TDI. no change there.
I'm going to order vacuum hose line kit and am wondering if I should order another N18 as well? This issue has me scratching my head a bit.
Thanks in advance!
With regards to N18
Thanks in advance!
