40X40
Experienced
What? You can't RUN AMOK? I know someone who could mentor you...Let's just get back on track, shall we? I'll try to go through and clean it up when I have time (and desire - I'm not a stall mucker).
Bill
If the mkvii has a dip stick you can use this to extract the oil:So, from reading one of the earlier posts, it sounds like all the oil is drained out through a 10mm plug in the cap on the filter housing? No need to drain the pan separately?
You still need to drain the pan.So, from reading one of the earlier posts, it sounds like all the oil is drained out through a 10mm plug in the cap on the filter housing? No need to drain the pan separately?
The ones that are real thin and made in China...Please take a video for us also...so what brand of cinder blocks works best?
Is it really necessary for you to troll internet boards and induce people to become contestants for your awards?The ones that are real thin and made in China...Please take a video for us also...
The subject has already caused quite a commotion. I've said I'll stay far away from the subject lest it be rehashed again and again.Is it really necessary for you to troll internet boards and induce people to become contestants for your awards?
I think you mistook my sacrcasm. Did you happen to notice his screen name?The subject has already caused quite a commotion. I've said I'll stay far away from the subject lest it be rehashed again and again.
With that said:
Indeed! I was laughing when I read your postI think you mistook my sacrcasm. Did you happen to notice his screen name?
Does anyone make a bypass filter designed for the MK7 that would allow placing the filter(s) in a place that would enable topside oil changes?Well I do have a Pella 6000 for my Mk4, but since the Mk7 requires a bottom side filter change I guess I'll be draining the pan from the bottom too. The Pella offers very little advantage on the Mk7.
My girlfriend is picking up the Mk7 on Saturday, so I'm poking around on the forum to see what fun is in store for me to maintain it. It'll be a Comfortline TDI with DSG and the convenience package.
Now that would be the one thing that would keep me going to the dealership.Dealers are offering lifetime warranty (iner in Mobile, AL.) but the car has to be maintained according to the maintenance schedule by a certified, licensed shop. This might be a little expensive.
I haven't calculated just ow much that would cost, but I wager it would add a bit to the cost per mile.
Finally, a new idea that does not focus on those cardboard blocks for holding your car up! This idea has "wheels" (or legs, that is!).Does anyone make a bypass filter designed for the MK7 that would allow placing the filter(s) in a place that would enable topside oil changes?
Back yard jiffy lube pit for the win!Finally, a new idea that does not focus on those cardboard blocks for holding your car up! This idea has "wheels" (or legs, that is!).
I am a real Darwin fan. Natural selection favors the intelligent and cleverist of toads.
I still say the real solution is a grease pit! Working on it...don't lift it, get under it.
Except the European version has the filter up top... Doesn't it?Back yard jiffy lube pit for the win!
I would think that someone is working on a Bypass filter for the mkvii. Perhaps someone in Europe has one made already since the mkvii has been there for a few years now.
I believe the two engines are pretty much the same as far as oil filter location goes:Except the European version has the filter up top... Doesn't it?
I suspect this would be more trouble than it's worth. Once I do the first oil change on the car I'll have a better idea.
From pictures I've seen it doesn't look like a big deal to me. I don't care if I have to move a few hoses.
Having said that, a TDI without a top side oil filter is an abomination. But it sure drives nice!
Okay, I thought the Euro ones were on top because the study guide (Page 11 in document linked in previous post) for the EA288 motor shows this, labelled as "Oil Filter Module":I believe the two engines are pretty much the same as far as oil filter location goes:
As you can see the intake is taking up a good not of room on top.
