diesel steve
I put a taller and narrower tire on. Was suppose to be a 4.25% differance in the speedometer. I drove it on the freeway and noticed no differance in the rpm at 70 mph. With both size tires it turned about 2450. I expected the rpm to drop,even just a little. I know the taller tire is about an inch taller. Shoudn't the rpm drop enough to notice on the tach? I was going to recalculate the odometer for correct milage but this doen't make sense. I guess I will just figure out the milage with no adjustment for the taller tires. In theory it should get better milage. I don't know if this was worth it.
