Afterlooking att all the options for a hitch I decided to build and install my own 2" recieiver hitch.
Total cost: 6" reciever tube $14.99, 2 x 2 x 1/4" angle $19.99, 7 way trailer wire connection $27, license plate frame from salvage yard $20, License plate light bolts $29, 4 7/16 grade 8 bolts and nuts washers and lock washers $2.50, ball and mount $19.99.
total: around $135
Here are some pics:
This is the car after the hitch install:
This is the frame that I fabricated and mounted to the car frame:
I welded 7/16" grade 8 nuts to the 2" x 2" x 1/4" angle that is inserted 20" into the frame rails.
Then I bolted themto the fram and used 2 1/2" peices of scrap angle as washers or reinforcing brackets from underneath.
This is the rear drivers side bolt which I bolted through the rear muffler hanger's rear bolt hole. I had to drill out the hole on the bracket as well as all the way through the frame to accomoodate ther larger 7/16" bolts
I had to trim the heat sheild to fit the angle reinforcing bracet above the muffler:
I used a flip down license plate frame from a 1996 chevrolet caprice and turned it 180 degrees. This moved out the plate 3/4" and the factory lights were not aligned anymore so I had to use license plate light bolts from a motorcycle shop to still have legal license plate lights.
Here are some finished pictures:
