Is torque some how limited in the first three gears on the DSG cars? I drove both MT and DSG cars and the DSG feels lot sluggish in the first 3 gears when you press the throttle abruptly.
There is alot going on in both of these EA288 CRUA configurations (auto-dsgs/manuals). Each gear has its own drivers request map that governs the fueling/load request wrt rpm and fueling, temp, etc. If you have a cold engine, there is alot more throttle attenuation/correction preventing full power. It's all about emissions too, so don't think the engineers would allow a full throttle fuel dump from stop.
There are some other maps as well including torque and injector pulse that are maf dependant as well. So when the egr is cycling/open during tip-in, you'll have more lag than if its off. The only limiters for the trans are max wot torque at max request not ramping. DSG gears 5 and 6 actually have less request % that earlier gears. I have found other mapping 2D non-linearities that no other tuners touch or know about. Actually popular mapping sw most tuners use, doesn't even allow you to edit this data area.
Not limited to vw's, but BMW's MB's, Ecodiesels, etc. are all Bosch controlled, including limiters for EGT, cylinder pressures, and MAF, and lambda tables.
I have exhausted R&D efforts on DSG's for many years since I enjoy driving a properly programmed TDI/DSG over a manual. The ecodiesel 8spd is most impressive / awesome prime mover next to the MB 7spds, and BMW d's.
I've discussed this subject many times, here is a a link.
Jeff ;-))
http://forums.tdiclub.com/showpost.php?p=5330388&postcount=11
