Old August 7th, 2011, 23:35   #1
Scott_Martinez
Fuel Economy: 48mpg
Default Making sure
My wifes '03 Beetle is throwing a fault code 17964. I did break the little nipple on the valve on the booster hose while changing the air filter and not catch it right away. I also had replaced the injector pump seal right about this same time. I replaced the hose a week or so later, but never got the full turbo back. The actual MAP (Group 11) is about 1/2 what Vag-Com say's they are supposed to be at idle. I am wondering what I missed or if the N75 just happen to fail about this same time. I was trying to see if I could get the MAP reading up by plugging the vacuum hose to the turbo, but it remained mostly unchanged. The rest of the vacuum lines including to the reservoir seem fine. I feel like this is something I missed from the previous repairs, but it all looks good. Anything thoughts on what I should check next?
Thanks,
Scott
Scott_Martinez is offline   Reply With Quote
Old August 8th, 2011, 01:31   #2
runonbeer
Maintenance EnthusiastVendor
Fuel Economy: amazing/excellent/still pretty good
Check injected quantity.
runonbeer is online now   Reply With Quote
Old August 8th, 2011, 11:04   #3
Scott_Martinez
Fuel Economy: 48mpg
Default Looks good
Just the MAP is low, all the other groups look fine.
Old August 9th, 2011, 10:22   #4
chromeBuddha
chromeBuddha's Avatar
Fuel Economy: 47 mpg @ 75 mph
If you replaced the valve that you broke the nipple off, did you make sure you oriented correctly. I think it is a one-way valve and if backward wouldn't allow vac through.
2002 Golf TDI, 5-speed, 2-door
White w/ Tan interior (get the Scotchguard!!!)
47 mpg @ 75 mph
"El Bonbon" - The Marshmallow
chromeBuddha is offline   Reply With Quote
Old August 9th, 2011, 19:57   #5
Scott_Martinez
Fuel Economy: 48mpg
The booster hose came with the valve in place. I wondered about another check valve that tee'd off and went to the vacuum reservoir, but I don't think I ever touched that. I have vacuum at the N75. I think I just need to get the car on a lift or blocks to see what's happening around the turbo. I seem to have low end power, just no boost.
making my own TDIFred Ontario 19 November 4th, 2013 19:15
Making your own Golf87 Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 10 June 10th, 2006 22:15
Making a Vag-Com LukeJetta TDI 101 19 April 28th, 2003 13:14
Making your own fuel! Fabia TDi Fuels & Lubricants 1 October 20th, 2002 17:35
is anybody making their own biodiesel? applehead Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 11 May 19th, 2002 14:06
Page generated in 0.15083 seconds with 11 queries
[Output: 69.16 Kb. compressed to 61.29 Kb. by saving 7.87 Kb. (11.37%)]
