TDikook
I finally got my Golf sound Deadened with Raammat sound deadening product. http://www.raamaudio.com Frst the Raamat is an OUTSTANDING product. I reall enjoyed using it. I have sound deadened two other cars before this one. and using Raamat was much more pleasurable that the other times. it is not an asphalt based product, it does not stink and makes absolutely no mess what-so-ever, except under my thumb and my middle finger nails. I did two vehicles with Raamat and both went very well. producing excellent results, but more on that later. Let me say that this is a very very time consuming job. It will not go quickly unless you have multiple people helplng you.
I started with my 2006 Golf TDI. and First thing first, EVERYTHING must come out. every piece of trim, which I found out, there are a ton of trim pieces for the Golf.
[/IMG]
this is the very beginning of the job
most are pretty straight forward. I did use my Bentley which helped a little bit, but was still unclear on some pieces. and to my dismay, even though I was careful, I still broke off a bunch of plastic tabs. I think they make them to break, they are so brittle. but some are not in the bentley or was unclear. Like the trim pieces over the wheel wells. there is a screw in the back(on the rear) that is easy to find, but there is a clip that is invisible. it can be accessed by a screw driver through the hole in front of it. push the tab in and it comes up.
[/IMG]
[/IMG]
[/IMG]
[/IMG]
also the very rear trim piece. it is just pulled off. and is help on by plastic clips that can break. I broke two of about nine of them.
[/IMG]
[/IMG]
another tricky piece was the rearend of the center console. I have cup holder that pulls out. that is where I got stumped. the bottom plate has to be pryed off, there are five tabs, two shaped like hour-glasses and three regular clips. I gently put a flat screwdriver under it and pryed it up. I did not break any of these. I was happy.
[/IMG]
[/IMG]
next page continues:
