This all happened yesterday (Saturday).
So I took care of the tires. I also took care of extra wheel sets with worn tires and mounting a new set as well as a couple of singles. In all, I took 12 tires to be thrown away, I have 2 spare wheel and tire sets as well as what's on the cars, and a lot more room in the garage.
And after a road test, the following is fixed:
1) The a/c works. Even after sitting a couple of days since recharging the system, it works. And while it was not blisteringly hot yesterday late when I took my test drive, it put out frost bite cold air, so I'm happy with that. The vibrations I was getting from a normal drive can be readily attributed to road surfaces and the fact that those tires on the car are actually snow tires. I'll probably need to change that before my next road trip, but if there's no time it won't be a big problem and I'll just turn up the radio until the wife objects (which will take her about 2 minutes).
2) Inner CV joint vibrations gone. They were gentle, hard to even notice. Usually people wait until they complain about steering wheel shimmy, but mine only had 2 pits on one of the joints, so the vibration was hardly noticeable.
Now the only thing left (yeah yeah, I forgot about this thing above) is to cure my turbocharger's reluctance to produce boots. I am convinced that it is due to a very worn actuator ring since the CHRA appears to be just fine.
Got a spare in the garage, so I'll use that if it checks out. It has a lot less mileage (less than half, IIRC) so in all likelihood it will work. I just need to find a way to stick a wire in there to see if the vanes exhibit much in the way of play. In this case I'll be looking to see if it is obvious that it has the same problem as my OEM unit, since a definitive examination would require disassembly. I don't really have time for that right now.
Oh, and I happen to have some spare OEM wheels. If you want a set of Avus, Santa Monica, Hakunamatatta, Fat Fives, Long Beaches, or Keskin KT-5s, check my for sale thread. No photos yet, but lots more detail.
Cheers!
PH
