dieseldorf
web page
OK, this all started about 6 weeks ago when forum brother bcost (Brian) removed the engine from his 2000 Jetta (115k miles) to do a timing belt, install an x-flow IC, VR6 clutch and a few other maintenance items.
As of earlier this week, most work had been completed and the car ready to be re-assembled. New TB was installed and the engine rotated freely while on the engine stand…no obvious issues, everything looking good. Brian got the engine re-installed and the transmission bolted up. For some reason, they can ONLY turn the engine about 180* and then it hits something “blunt”. The engine can then be rotated 180* in the opposite direction and hits something “blunt” again. They thought a bolt may have dropped in (following transmission installation) and was causing interference.
Today they removed the TB and have lifter the cam. For some reason one of the lifters does not appear normal and can be depressed by finger…it’s only one lifter…the others all appear normal (meaning they can’t be depressed).
They are getting ready to remove the head to see what’s going on.
Is the head gasket re-usable? Do the studs have to be replaced after the head has been removed? Right now the starter is out, slave cylinder is out and TB removed.
I know they’re getting kind of frustrated with it so if anyone has any great ideas, I didn’t, they sure would appreciate it.
Brian, Bill and Alex are at 781 551 3399
Thanks for any insight!
