v-dub-u
I bought a 06 with very low miles for very cheap, the guy claimed had a bad engine . figured i would take a chance. He Sold it due to oil psi light coming on and shutting down engine.
Hooked up manual gauge and started it ,found sensor was fine, was not building any pressure. Started it with sensor out and nothing came out. ( yes i know it's not good to run it without oil psi but it's the only way to diagnose it.
Dropped the oil pan and found At one time it had a cheap oil filter on it and clogged the pickup tube, removed pumped and cleaned it out and dropped #1 & 4 main caps and found bearings looked very good surprisingly. Stuck them back up temporally and started engine. Engine built oil psi (steady stream comes out oil psi sensor) but won't build over 5 psi. I'm thinking maybe the filter came apart and is holding open pressure relief valve open. Any other opinions out there ? My questions (1) are the main bolts stretch bolts and does anyone have the specs (2) where is the pressure relief valve on a brm, thinking its on filter housing.
