I have a 99.5 Jetta TDI 5 speed. 230K
I was wondering if I could get some thoughts.
At about 55mph I get a steering wobble, so naturally I jacked the car up and start checking for play.
All ball joints and tie rods are tight, as to be expected, I did a complete suspension/steering job about a year ago. Only thing I didn't replace was wheel bearings and rack and pinion.
There is a little play, about 1/2 inch horizontally in the rack and pinion, my question is this normal or is this my culprit? There are NO leaks in the system.
Also I read somewhere on here if the bearings are bad there will be no play like normal faulty bearings, is this correct?, there is no obvious play vertically like a faulty bearing would show?
Not sure what direction to go here. Both fixes are expensive and I want to make sure I replacing the correct parts.
Appreciate any input,
Josh
Josh
