Well I am just about done with this head replacement and new Tbelt for my 02 ALH engine. Got it running after quite a bit of cranking to get things primed, and it idles fairly well. Problem I am running into is it won't rev much past idle. It starts and idles fine now, but when I hit the accel pedal, the rpms go up to maybe 1000 or so and then stop there. Even with the pedal floored. Returns to idle just fine, but won't go to higher revs. One other thing, it does smoke a lot, really alot at idle.
So I am guessing that my timing is off. I have a VAGCOM, but one is supposed to run it until it gets to >180F to do the timing adjustment. That could take forever at idle, to say nothing about smoking up the garage and lower level of the house.
So my question is, if I were to "adjust" the timing a bit without the benefit of the VAGCOM, which way should I try, a bit more advanced or retarded? Or is there some other problem I should check out first?
Thoughts?
Thoughts?
