DocMaddie
Howdy. This forum is amazing and I've been reading for weeks as I take the plunge away from my '82 Mercedes 300D and into an '05 Mk4 Jetta TDI GLS wagon.
The car runs very low to the ground. About 4" clearance from the lowest part of the undercarriage (rear suspension component). Factory stats show 5.2" clearance, so I've lost at least an inch. I am planning to put a hitch on, go to snow/fire roads etc... so I really need all the clearance I can get.
I am trying to figure out if the suspension has been lowered intentionally or is just tired. The suspension on the car is not stock. There are Bilstein yellow struts up front and bilstein yellow shocks in the rear. All of the springs are black. There is a red stabilizer bar in the rear which seems to be aftermarket as it is connected to a drop linkage on both sides and rides very low to the ground. The dampening on all 4 wheels is very good, and the car rides great. At visual inspection all of the suspension linkages appear tight and clean. I am hoping this is just a case of tired springs.
Does anyone have any suggestions on how I could read this suspension, markings etc... to determine if any lowering funny business has happened?
Also, quick related question - car supposedly has ESP based on it being a 2005 TDI GLS, but there is no disable switch on the dash and no indicator light comes on when you first start the car. I can not find the options code sticker that supposedly is found in the cargo area somewhere. Do I have ESP but just no disable switch?
Thanks!
Thanks!
