Need help with ECM - no communications error
SuperAdellic
Beaufort, SC
None
Just bought a new to me Golf and it started idling rough. It runs fine, maybe a little low on power (this could be that it is stock and my previous Golf had a tune and nozzles), but the idle is rough. Background is it's an automatic to manual swap car (the TCM is still in the car) and it has a 10mm IP on it (I don't know the story on that and neither does the previous owner). The engine coding shows 00002 (manual transmission). When I scanned it with VAGCOM the below scan is what I got. What caught my eye was the instruments and CAN gateway are showing the same errors: 01314 ECM - no communications - intermittent and 01315 TCM - no communications. Why would the instruments and CAN gateway still be looking for a TCM if the ECM is coded to manual transmission? What is causing the intermittent no communications with the ECM? Any help would be greatly appreciated. Thanks,
SA
Sunday,01,July,2012,17:36:09:21184
VCDS Version: Release 11.11.3 (x64)
Data version: 20120401
Chassis Type: 1J - VW Golf/Bora IV
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
Mileage: 343740km/213590miles
Address 01: Engine Labels: 038-906-012-AGR.lbl
Part No: 038 906 012 BD
Component: 1,9l R4 EDC G420SG 2507
Coding: 00002
Shop #: WSC 02424
VCID: 53AB80D5A1EE691
No fault code found.
Readiness: 0 0 1 1 1
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 P
Component: ABS 20 IE CAN 0001
Coding: 03504
Shop #: WSC 01317
VCID: 3E7DC1613A6C949
Part No: 6Q0 909 605 A
Component: 09 AIRBAG VW5 0003
Coding: 12345
Shop #: WSC 01317
VCID: 356FDE4D0F5A571
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 1J0-920-xx0-17.lbl
Part No: 1J0 920 900 M
Component: A4-KOMBIINSTR. VDO V16
Coding: 07242
Shop #: WSC 02402
VCID: 2C59FB29DC10169
Subsystem 1 - Part No: IMMO
Component: IDENTNR: VWZ7Z0X1766574
IMMO-IDENTNR: VWZ7Z0X1766574
3 Faults Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to Plus - Intermittent
01314 - Engine Control Module
49-10 - No Communications - Intermittent
01315 - Transmission Control Module
49-00 - No Communications
Part No: 6N0 909 901
Coding: 00007
Shop #: WSC 01317
VCID: F0E1AF59B0B8B29
2 Faults Found:
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AJ
Component: 60 Zentral-SG Komf. 0001
Coding: 04096
Shop #: WSC 01317
VCID: 860DE981A23C8C9
Subsystem 1 - Part No: 1J1959801C
Component: 60 Tırsteuerger. FS0002r
Subsystem 2 - Part No: 1J1959802D
Component: 60 Tırsteuerger. BF0002r
Subsystem 3 - Part No: 1J4959811C
Component: 61 Tırsteuerger. HL0002r
Subsystem 4 - Part No: 1J4959812C
Component: 60 Tırsteuerger. HR0002r
4 Faults Found:
01329 - Convenience System Data Bus in Emergency Mode
35-00 - -
01333 - Door Control Module; Rear Left (J388)
00943 - Heated Exterior Mirror; Driver Side (Z4)
35-00 - -
00915 - Window Regulator Switch; Rear Right; Driver (E55)
29-10 - Short to Ground - Intermittent
End ---------------------------------------------------------------------
jef@rosstech
Associate Ross-Tech Vendor , w/Business number
knoxville
2004 Dog hauling, wood towing, pinball stashing Jetta wagon
The Gateway is coded for automatic. Change the Gateway coding to 00006, clear codes and then see where you stand.
SuperAdellic
Beaufort, SC
None
Thanks Jef. It cleared up the ECM, TCM, and airbag errors. The temp sensor error and data bus in emergency mode have stuck around. New scan results are below.
Monday,02,July,2012,17:12:14:21184
76
Mileage: 343850km/213658miles
Coding: 00002
Shop #: WSC 02424
Readiness: 0 0 0 0 0
Coding: 03504
Shop #: WSC 01317
Coding: 12345
Shop #: WSC 01317
Coding: 07242
Shop #: WSC 02402
1 Fault Found:
Coding: 00006
Shop #: WSC 01317
Coding: 04096
Shop #: WSC 01317
1 Fault Found:
35-00 - -
jef@rosstech
knoxville
Verify wiring between instrument cluster and temp sensor are good. If so, then I'd suggest replacing the coolant temp sensor.
http://wiki.ross-tech.com/wiki/index.php/01329
Connect to the Comfort Control Module and go into Measuring Block group 012 and see if field 1 shows 1 wire or 2 wire operation. If it shows 1 wire operation, verify CAN Gateway wiring to door modules are good. You can also try unplugging the door modules and see if it goes to 2 wire, sometimes they can fail internally and cause something like this to happen.
However, on the Comfort Bus, it it is in 1 wire operation, you would never know it, everything will still operate normally.
