rawdon1
- Joined
- Apr 5, 2007
- Location
- Upper Rawdon, Nova Scotia , Canada
- TDI
- retired the 2002 Jetta after transmission went again...... now got a 2000 tdi jetta manual tran....... now driving 2003 jetta wagon 5 speed
Friday,13,January,2017,10:10:32:07943
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 17.1.0.0
Data version: 20170106 DS267.0
www.Ross-Tech.com
Dealer/Shop Name: Carter
VIN: 9BWGR21J164008493 License Plate:
Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
VIN: 9BWGR21J164008493 Mileage: 449210km-279126miles
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 038 906 016 AG HW: 028 101 181 2
Component: R4 1,9L EDC G000AG 7000
Revision: 12345678 Serial number: VWZ7Z0E2493972
Coding: 0150034
Shop #: WSC 00000 785 00200
VCID: 59B28F7193067589E8-515A
1 Fault Found:
17036 - Sensor Reference Voltage B
P0652 - 000 - Too Low
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Bin. Bits: 00100000
Bin. Bits: 00000000
Bin. Bits: 00100000
Bin. Bits: 00100000
Bin. Bits: 00000000
Readiness: 0 0 1 1 1
Address 02: Auto Trans Labels: 09A-927-750.lbl
Part No: 09A 927 750 BL
Component: AG5 Getriebe 09A 0262
VCID: 76E8E4CD52D83AF1E5-513C
2 Faults Found:
00529 - Engine Speed Signal Missing
03-10 - No Signal - Intermittent
01314 - Engine Control Module
49-10 - No Communications - Intermittent
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0004097
VCID: 336E1DD9512A6FD902-513C
1 Fault Found:
00668 - Supply Voltage Terminal 30
008 - Implausible Signal - Intermittent
Part No: 1C0 909 605 A
Component: 1M AIRBAG VW51 02 0008
Coding: 12621
Shop #: WSC 00000
VCID: 2240E89DAED0F651F9-5120
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 807 F
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 15334
Shop #: WSC 00000
VCID: 2B5E05B9D91A37194A-5120
9BWGR21J164008493 VWZ7Z0E2493972
3 Faults Found:
01315 - Transmission Control Module
01304 - Radio
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 00000
VCID: 70E4D2D530BC14C13F-5120
3 Faults Found:
01304 - Radio
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 8C Komfortgerát HLO 0004
Coding: 00258
Shop #: WSC 00000
VCID: 377629C9155283F93E-4B00
Subsystem 1 - Part No: 1C1959801A
Component: 8C Tõrsteuer.FS KLO 0202
Subsystem 2 - Part No: 1C1959802A
Component: 8C Tõrsteuer.BF KLO 0202
Subsystem 3 - Part No: 1C0959811A
Component: 8C Tõrsteuer.HL KLO 0202
Subsystem 4 - Part No: 1C0959812A
Component: 8C Tõrsteuer.HR KLO 0202
18 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
53-10 - Supply Voltage Too Low - Intermittent
00849 - S-contact at Ignition/Starter Switch (D)
25-10 - Unknown Switch Condition - Intermittent
00928 - Locking Module for Central Locking; Front Driver Side (F220)
54-10 - Incorrectly Equipped - Intermittent
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
00930 - Locking Module for Central Locking; Rear Left (F222)
00931 - Locking Module for Central Locking; Rear Right (F223)
00956 - Key 2
09-10 - Adaptation Limit Surpassed - Intermittent
01179 - Incorrect Key Programming
35-00 - -
01331 - Door Control Module; Driver Side (J386)
52-10 - Supply Voltage Too High - Intermittent
27-10 - Implausible Signal - Intermittent
01332 - Door Control Module; Passenger Side (J387)
01359 - Internal Central Locking Switch; Passenger Side (E198)
01333 - Door Control Module; Rear Left (J388)
01334 - Door Control Module; Rear Right (J389)
Address 56: Radio Labels: 3B7-035-1xx-56.lbl
Part No: 3B7 035 180 F
Component: Radio PM6 0020
Coding: 00401
Shop #: WSC 00000
VCID: 234EED99B1CAFF59F2-513C
2 Faults Found:
00856 - Radio Antenna
36-00 - Open Circuit
01336 - Unlicensed Version. Not all DTCs
37-10 - will be decoded. - Intermittent
End-------------------------(Elapsed Time: 05:07)--------------------------
www.Ross-Tech.com
76
Coding: 0150034
1 Fault Found:
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Bin. Bits: 00100000
Bin. Bits: 00000000
Bin. Bits: 00100000
Bin. Bits: 00100000
Bin. Bits: 00000000
2 Faults Found:
Coding: 0004097
1 Fault Found:
Coding: 12621
Shop #: WSC 00000
1 Fault Found:
Coding: 15334
Shop #: WSC 00000
3 Faults Found:
01304 - Radio
Coding: 00006
Shop #: WSC 00000
3 Faults Found:
01304 - Radio
Coding: 00258
Shop #: WSC 00000
18 Faults Found:
00956 - Key 2
35-00 - -
Coding: 00401
Shop #: WSC 00000
2 Faults Found:
