roadracer1966
FS: 2003 Audi TT Quattro TDI – California Certified (CARB Legal) or so I thought!!!
With a new project in the wings I’m forced to sell one of my favorite conversions, my TTq-TDI :-(
This is quite possibly the closest to factory, TT Mk1 TDI conversion that exists. 99% of the parts used are factory part numbers. The beauty of VAG is a lot of the parts can be mixed and matched across brands. My idea was basically put a Euro A3/S3 4-Motion TDI (PD130) into a US TT quattro Mk1 with some “enhancements” along the way AND make it California street legal (NOT CARB Referee Certified - see post below) .
I started in 2009 and it took 3 years to find the perfect donor, 2003 TTq. I chose that so the dash, k-line, CANBus and harness would all line up (for the most part) with a Euro A3. After I got the TT, I spent two years accumulating parts from Ryan Parkin (aka ryanp of Darkside Developments, UK, what an awesome guy!). I got from him a ASZ/PD130 from a 2003 Golf GTD as well as everything attached to it. Also a 02M DRW 6-speed. I built the motor to race spec using as much ARP hardware as I could find. After the motor and transmission were complete I spent 500 hours mapping and building the wiring harness (starting point from charliet and danielhf spreadsheet). The 2003 A3 ECU uses the Bosch EDC15P+ which has a huge public knowledge base (i.e. internet forums, e.g www.ecuconnections.com, etc.) and a lot of hardware/software tools. I enlisted the help of Marin Mihaljcic (aka Jetta, 97) to do the initial ECU and cluster work (he’s super awesome too by the way). After Marin set the baseline I took over and tweaked the firmware on the EDC until I got it to where I wanted it (with much help from extreme EDC hacker Colin from France). Along the way I found this amazing product called FIS-Control and worked with the inventor/builder/developer Stefan Bieger. I used his product to to monitor the EDC, 02WideBand senor and EGT. I can read measuring blocks, read codes, reset codes and even change the ECU mapping as well as monitor external sensors. All from the center display on the S3 cluster. Yes, a S3 cluster fits in a TT bezel with some minor work. It looks and acts totally factory. I’ve been driving the car for two years and it’s a hoot (in the dry and wet) without a single problem. I have absolutely no codes/MIL/CEL. Everything just works (including the quattro and A/C)! My average MPG is 38-40 and on a long trip I got 48! Not bad for a AWD Sports car The best part is you can take this car to any VAG TDI mechanic and they will have no problem working on this car. To them it will look like BEW Golf/Jetta except it has a angle drive for the rear wheels. I will be including all my documentation/spreadsheets/firmware/flashing tools/Custom EDC15P+ bench dongle/VCDS HEX-CAN dongle/MPPS dongle/VAG Commander dongle/Repair manual CD’s/Bentley manual.
Prior to all of this, I sent numerous letters and emails to Audi North America, pleading with them to bring the TT TDI to the US. Every time I was told that there is no market for that configuration in the US. Hence, I ended up building my own. If you ever wonder how much something like this costs… well I have $38k into this project and that’s not including my time (~1000hrs of labor/research/tuning). I’m asking $13,000 and I think that’s a steal for someone looking for such a configuration.
Car/Project Gallery:
https://goo.gl/photos/RvkhFoJmiLxRMbay7
Videos of S3 Cluster and FIS-Control:
https://youtu.be/WEjI2HDDwIc
https://youtu.be/WQc7ZYMFvIc
Harness Rewire Spreadsheet:
https://drive.google.com/open?id=0B3S8SR-d9Q8YdXJwMFdPdFB2WDg
Car Details:
2003 Audi TT quattro
The car has 83,000 miles and the TDI has 8,000 miles
White Exterior
Light Blue/Grey Leather Interior
6-speed
42 Draft Designs - 3" CAT-Back Exhaust system
Neuspeed Short Shift kit
Audi Concert Sound
Xenon HID Headlights (factory)
Audi Factory 18” Sport Wheels w/ ContiProContact p225/40-18
S3 Euro Cluster w/ factory white faces
FIS-Control integrated with S3 Cluster presets as boost gauge, AFR gauge and EGT gauge
IMMO fully functional (Marin matched the EDC, Cluster and Keys) just like from the factory
Immaculate condition, it looks and runs like a new car!
Engine:
ASZ (PD130) 180hp/340ft/lbs @1950rpm (that’s about all the GT1749VB will muster reliably @1.6Bar/23psi)
Machine work by Sean at Star Machine in Emeryville, CA
Cleaned, mag’d, honed & decked (.002)
Colt Cam Stage 2
Nitrited Black lifters
ARP, Head Studs Custom (per CharlieT mod)
ARP, Main Studs
ARP, Rod bolts
BEW Injectors w/ Bosio Power Plus 1043 DLC built by DBW
New injector harness (inside engine)
Sputter Bearings
New Oil pump w/chain
Factory ASZ pistons
New timing belt, idler, pulley and sprockets
VNT-17 Turbo (GT1749VB)
New Factory turbo drain hose
Factory TT dual inter-coolers
Factory 4-motion down pipe
Ecotrons Wideband Lambda ALM-Board w/LSU4.9D Bosch sensor (preset #2 on FIS-Control)
2M EGT K Type Thermocouple Exhaust Probe (preset #3 on FIS-Control)
PD150 Passat Intake (intake opening on the gearbox side for ease of intake plumbing)
PD150 Air cleaner to turbo intake plumbing
Basically anything that needed to be replaced was replaced with factory VAG parts.
Transmission:
Built by Matt at Whitbread Performance
Transplanted DRW gears into the TT quattro transmission
pinned and welded shift forks
New Syncros & Bearings
ARP, Ring Gear bolts
Sachs SRE Performance Clutch and Flywheel
Factory Euro TDI steel Angle drive support bracket (replaced the 1.8T aluminum bracket)
Heavy duty axles both left and right fronts from Marty at RAxles
2000rpm@72mph in 6th gear
Fuel System:
Factory A3 TDI 4-Motion fuel pumps/senders (split tank on quattro)
Viton lines and o-rings everywhere
Spares:
2 – backup EDC15P+ ECU’s
Stock TT Cluster w/ SKC key that matches S3 cluster and ECU’s
Garrett GT1749 CHRA (cartridge housing rotating assembly) needs balancing
Tandem pump
A/C compressor
Alternator
Test pipe to replace the CAT (used for development)
Blanking plates for EGR (used for development)
Car Details:
White Exterior
6-speed
Audi Concert Sound
Engine:
Colt Cam Stage 2
ARP, Main Studs
ARP, Rod bolts
Sputter Bearings
Factory ASZ pistons
Transmission:
Fuel System:
Spares:
Tandem pump
A/C compressor
Alternator
