compu_85
Gadget Guy
What's the average oil pressure at hot idle for a TDI?
-J
-J
12-15 psi on my BEW with 5w-40What's the average oil pressure at hot idle for a TDI?
-J
but they also limit low end torque a whole lot in their softwarethey obviously did there calculations that the pump puts out enough at low rpm.
How would that affect rpm? If the engine is at 1500 rpm, the oil pump output is fixed barring something plugging up or a bearing going out. Pressure will change due to oil viscosity as it gets warmer and clearances getting loser.but they also limit low end torque a whole lot in their software
not rpm, but bearing load, piston bowl temperature, etcHow would that affect rpm?
Good info.not rpm, but bearing load, piston bowl temperature, etc
all go up when bringing the engine from box-stock config
"they deemed the oil flow sufficient" ...for a 90hp turd with next to no bottom end
look at the tq limit maps and see that they hit zero at 500 RPM, 20 mg/str at 501 rpm, mine allow full fuel down there and it improves drivability quite a lot starting from a rest, but the bearings are getting an awful harsh loading with very low oil pressure/volume
same with piston bowl temps, they can get very hot at low revs with no oil flow and tweaked fueling. Stock programming makes it impossible to hurt the engine with the throttle, but tweak it and you can easily melt pistons with all stock hardware by lugging the engine around
agreed. I removed my check ball and springs (also larger drilled holes) but you can only do this with high volume pump. Without the bigger pump gallery pressure will be too low for rotating assembly. Very nice work on all the testing btw.The drilled holes in the bolt are not the primary restriction, the spring and check ball are. If the cracking pressure is the same between the two bolts, I don't think there will be a significant difference between the two. If you want to send me a couple of the other bolts, I can run a similar test with them and see if there are any differences.
First off great read and thanks for all the info. Second thanks for the good info on these T4 pistons! I just acquired a full set with a few other goodies for a price I couldn't pass up. Great to know that they'll hold of to daily abuse!Well
Just to show an example,a few weeks ago I opened an AFN engine which had digested a bolt through the turbo...
This engine was built by a friend back in 1999 and has had a myriad of turbo,injector combos
Engine had 255chp on last dyno and has been more or less daily abused since 1999
When I opened the engine I saw that it had transporter t4 Pistons with no cooling gallery.
Because in 1999 there was no PD Pistons available
Furthermore I noticed that the oil jets were removed...,,.,
T4 Pistons has oil jet notches on other side so my friends solution was to remove the jets and plug the holes he he
Anyway,Pistons had no wear or other heat related issues
FUB States:
..."4) The bolt is the dominant restriction in the squirter assembly which leads to #5
5) Increasing the squirter size from 0.076" to 0.096" only increases the net area of the two orifices in series (bolt + squirter) by ~10% which changes the differential pressure at 1 LPM from ~1.7 to ~1.4 bar (24.6 to 20.3 psi) Of course that oil pressure drop will also be seen by all the other passages in the engine so their oil consumption will be reduced so the actual drop for the squirter will be less than that. Solving for this is very difficult since there's about 100 orifices in parallel and they're all interdependent on each other.
After reading from FUB that the oil squirt bolt was the restriction, I remeasured the orifice of an oil squirt bolt and actually found there are two different types for the engines starting with the AHU's and everything forward from there. I do not know what the split year is, but I assume the early oil squirt bolts have what I measure as a .076" orifice to the check ball, but the later once have a .120" orifice. Here are pics...
The bottom set are the smaller orifice bolts.
Also, notice the inlet holes for the older (left) squirt are smaller than the larger orifice bolt on the right.
Tops of the bolts look different. Again, smaller orifice bolts are on the left and have a ring groove on top of the bolt...
Last two pics, show large orifice bolt with "WAG, 8.8 imprint. Smaller just has ring.
Anyone with the smaller orifice check ball will be able to visually inspect their oil squirts and tell if they have the smaller or larger oil squirts. Depending on opinion, my feeling is that VW usually has a good reason for updating things like oil squirts.
All the data for the larger oil squirt will have to be re-evaluated. I am sure the volume will now change, as 1) there is definitely no restriction in the larger bolt for oil flow going through a .096 oil squirt orifice hole and 2) The orifice and spring pressure will have to be retested for the larger check ball and spring.
There is more I need to bring up about the Volume/ Pressure of the oil pump, as I think some of that information is confusing. The pump may be a 'set volume pump', but under low-speed situations, the pressure will dramatically drop. Any oil pressure loss due to loose journals, worn bushings or any of the pressure relief orifices weak or sticking will affect low speed oil pump pressure and volume rather dramatically
Yes indeed...Are you sure?
Frank, do you think the intake manifold configuration is the main contributor to that uneven load on number 3. Visually it seems the path of least resistance. If so, Has any custom manifold design turned out to be better?That allows for 100%, 360 degree duty cycle for oiling the harder worked #3 rod
