jimbote
Certified Volkswagen Nut
a little back story: i'm retro-modding a 69' fastback mustang with all new MII front suspension, 03' cobra IRS, new pans, rear quarter, tons of new parts already on hand (bought as an abandoned project)... i've settled on a Mod 4.6 engine/5r55s swap from a 2004 lincoln aviator ... i bought a rolling shell with only 4,500 miles! apparently it fell off a transport truck at the dealer back in 04' or 05' smashing the roof and the side in ... went through a few hands before i spotted it on CR and snapped it up... here's the problem, it does not have the original key and of course the PATS system is preventing cranking, fuel pump operation, and injector firing ... i towed the truck to a local modular performance dealer and had the ecm flashed along with a PATS (securilock) delete ... still same issue, so i installed a second known good ecm on the spot and no different... i towed it back home and checked every related ground, fuse and wire between the ecm, relays, and modules ... it's all in order...the ecm is not grounding the starter relay, is not grounding the injectors, and is not grounding the fuel pump driver module ... i can jump the starter relay ground and run it on ether so the coils are firing .... my question is this: is there something special about the lincoln ecm that requires an extra step to turn off PATS that the tuner may have missed ? ... i know this tuner mainly deals with mustang ecms so i'm not even sure he's encountered this issue before... thanks for reading and any pointers in the right direction would be greatly appreciated.
