S4Jeff
SO, I Know there are ton of threads about the 02J-02M tranny swap. So, I have an opportunity to pick up a 2003 Jetta VR6 that has the 6 speed manual trans in it, for cheap. What I'm thinking of doing is swapping out the trannys, take the 5 speed and put it in the vr6 and put the 6 speed from the vr6 into the TDI. Once that is done I will either part out the old VR6 or I'll fix the motor and sell it.
Question is which for some reason I can't find it. I believe that the 6 speed tranny is the correct one for the swap? I got confused because I found some threads that made it sound like there are different versions of the 02M? Can anyone confirm that the tranny is a direct swap? Of course with the axles etc...
The other question is, is it really worth it? Will it lower my RPM's that much at 70-75 and save on fuel? I feel like it's worth the time and effort to swap them both over. Thoughts?
