priest
I have a 2.0 tdi that wont go over idle. It has a full rebuild including Franks TDI stage 2 cam. Frank also just rebuilt the head. So the top end is sound. The cam shaft position sensor and the crankshaft position sensor are new. Frank has had the car for awhile and can't figure out why it won't run over idle. It idles great just starts lugging and blows smoke as soon as you apply any throttle. Its still throwing the cam and crank sensor codes. Tried a new ecm and still the same problem. Any help is appreciated.
