Re: Help, can\'t hear the turbo!!!!!
These are classic symptoms of bad timing after a timing belt change. Check the timing with a scan tool, and you might also want to check the cam timing to make sure that the belt was installed correctly!
Good luck!
-davin
Good luck!
-davin
