Bill1975
2011 A3 CBEA, I changed the fuel filter for the first time since buying the car. Everything went fine, but I noticed some odd things when priming the pump. I tried both methods:
1) Engine -> Basic Settings -> Fuel Supply Activation (group 35) When I did this, I could hear the pumps activating, but I got an error message saying "Group 35 not available".
2) Engine -> Output Tests -> Fuel Pump Relay Control Circuit (I think this is the in tank pump) let it run, and I could hear the pump starting and stopping automatically. Then I selected "Relay for auxiliary fuel pump" to activate the pump in the engine bay. After 20-30 seconds it started making a whining sound as though it were sucking air. I went back and ran the in tank pump again, then the auxiliary pump for 5-10 seconds and the sound was gone.
Has anyone experienced this? It seems if you run them separately you run the risk of emptying the auxillary pump.
