Can y’all help me understand what this is and how to fix it? And do you know if it’s covered under the dieselgate extended warranty? I cleared it once but it’s come back. Then cleared it a 2nd time and haven’t seen anything yet... but only have 7miles since last clear.
1 Fault Found:
28388 - Coolant Pump 3
P26F4 00 [175] - Electrical Malfunction / Open Circuit
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 229774 km
Date: 2020.01.07
Time: 22:46:32
Engine speed: 831.00 /min
Normed load value: 28.6 %
Vehicle speed: 0 km/h
Coolant temperature: 48 °C
Intake air temperature: 28 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 13.880 V
Unlearning counter according OBD: 40
Heater support pump 1 bank 1 second.circuit: activat.: 94.79 %
Extern.temp.sens.1 bank 1: raw value: 9.5 °C
Shut-off timer: last engine shut-off time: 25393 s
Readiness: 1 1 0 0 1
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 229774 km
Date: 2020.01.07
Time: 22:46:32
