Old December 7th, 2009, 06:08   #1
tdiDerry
Default HELP - Brake indicator light flashhes with dinging
2005 Jetta GLS (old body style) Getting the loud dinging and BRAKE indicator light flashing while driving.. Usually when accelerating quicker or turning harder than normal.. and... It is getting more frequent.
Any ideas?? -Can this be something to do with the recall for the brake switch?
Thanks in advance, Derry
tdiDerry is offline   Reply With Quote
Old December 7th, 2009, 06:30   #2
RT1
RT1's Avatar
Fuel Economy: 43.3 mpg/10 Year Average - 80% HiWay
Did you check your brake fluid level?
'05 Golf PD - 396,000 miles
RT1 is offline   Reply With Quote
Old December 7th, 2009, 06:46   #3
jetta ,97
jetta ,97's Avatar
Fuel Economy: Very good
Yep,check your brake fluid level, you are probably due to do either front or rear pads or you have fluid leak.
I do any repair on all models,USED/NEW ECU and Cluster swap, Reprogramming Keys , Immobilizer Delete,Cluster LCD Dispay Repair -Clik here
I am trusted TDI Mechanic, VCDS
HEX+CAN
ECU TUNING-TDTUNING Authorized Dealer
MK6 Needle Sweep,MK5 with MK6 Cluster
jetta ,97 is offline   Reply With Quote
Old December 7th, 2009, 13:29   #4
tdiDerry
Thanks for the rapid response..
I feel like an idiot.. not because I didnt know this when it 1st started happening, but I just put in a frostheater and after I refilled coolant and drove it I got the dinging with the coolant indicator and I knew that was because it was low....DOH!
Thanks again..
Page generated in 0.12446 seconds with 10 queries
[Output: 58.99 Kb. compressed to 52.46 Kb. by saving 6.53 Kb. (11.07%)]
