TDICleanpower
Hello all,
My 03 ALH is getting old and worn out, (last oil sample was fine) but.... With the amount I drive in a year, I need some more reliability. So my thought was, buy a running engine, and build it.
Plan: Buy known running engine, strip down to block and crank, rebuild bottom end with new oil pump and bearings, install Rosten H-Beam rods, New head, ARP stud kit, 17+ turbo, Bosio DLC race 520 nozzles, (get the injectors calibrated), 11mm fuel pump, 3Bar MAP sensor, Stage 3 colt cam, and new 2.5" intake before and after turbo, with new bigger air to air. Where I get tripped up is the pistons. Im looking at the OEM with oversized rings, but am unsure if they will handle the power that the rest of the system can. So, what are yalls thoughts on the proper upgraded pistons for 250+ build? Thoughts on the build in general are welcome (yes im getting it properly dyno tuned at my local diesel shop)
