Go Back   TDIClub Forums > VW TDI Discussion Areas > General Automotive
General Automotive General automotive discussion. This is intended to be a discussion about other not VW and Diesel cars you may have or interested in.
Old July 26th, 2019, 09:57   #1
Amahlmann
Default Sunroof
Iíve had an issue with water in the cab I believe itís the sunroof leaking, is it possible to completely seal it off
Amahlmann is offline   Reply With Quote
Old July 26th, 2019, 11:04   #2
landcrabmechanical
Fuel Economy: 4.6l/100km 51.13mpg
Have a look at your sunroof drains. They are clear tubes that run down the A pillar into a black rubber holder. I had to silicone my tubes into the black rubber drains. Now no more water leakage. Also cut the pinch valve off the drains in the door jamb.
Sent from my STV100-3 using Tapatalk
landcrabmechanical is offline   Reply With Quote
Old July 26th, 2019, 11:53   #3
Amahlmann
Thanks I will take a look
Old August 5th, 2019, 10:10   #4
redbarron55
The drain hose is not sealed completely to the rubber nipples that push onto the sunroof drains.
They could be plugged, but I doubt it.
Search for sunroof drain nipples etc.
Here is one link:
http://forums.tdiclub.com/showthread...f+drain+nipple
redbarron55 is offline   Reply With Quote
Old August 15th, 2019, 22:32   #5
garreth5
TDI(s): jetta
Sometimes water can enter at the windshield plenum, so check that area also.
garreth5 is offline   Reply With Quote
Old August 17th, 2019, 08:58   #6
goodmonkey
goodmonkey's Avatar
A temp fix is to use a good quality duct tape around the sunroof. Very helpful it is going to be a rainy season and you can't get it taken care of right away. I've done that on a Jetta until I could fix it (had to drop the headliner) and have it right now on my Touareg until I can fix it as well. The sticky residue left behind is almost not worth trying to clean, it will wash off the paint over a couple months, but can discolor the sunroof seal for longer.
2014 Passat TDI SEL (DSG) - 91k, 2011 Touareg Executive -142k
Previous TDI's: 1996 Passat TDI- totaled at 394k miles, 1998 Passat TDI - 175k miles, 2012 Passat TDI SE - 41k, 1996 Passat TDI Variant - 327k, 2014 Jetta SportWagon TDI 6MT - 29k, 2015 Passat TDI SEL - 18k, 2006 Jetta TDI 5MT - 261k
goodmonkey is offline   Reply With Quote
Sunroof motor or sunroof problem?? surclay VW MKIV-A4 TDIs (VE and PD) 4 March 22nd, 2018 11:00
sunroof is on something rbscouter7 TDI 101 1 February 9th, 2014 10:13
Age old question. To sunroof or not to sunroof? TexJet VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 15 January 11th, 2010 19:52
Sunroof Help! PROBLEMO (sad sunroof) sfTDI VW MKIV-A4 TDIs (VE and PD) 11 November 30th, 2004 11:52
SUNROOF TDIBUG TDI 101 4 October 14th, 2001 17:33
Page generated in 0.13105 seconds with 11 queries
[Output: 71.83 Kb. compressed to 62.92 Kb. by saving 8.91 Kb. (12.41%)]
