2015 Passat TDI 2.0 DSG Overheat and died
ryanmonahan
Brantford, ON, Canada
2015 Passat TDI Comfortline Sport
For the last year my Passat has been losing about a cup of coolant each month. Dealer couldn’t find any leaks.
Today I topped it up and drove about 40km on Hwy and suddenly temp went way high. Pulled over and took a look coolant level was fine. I was right at an exit so I started back up to get off hwy.
Almost immediately it started beeping and lost power. Had to pull over as it stalled out. Got it towed to dealership.
When I first looked a bit of white smoke was drifting out from under the engine cowl. couldnt see any other obvious signs of trouble.
I’m at 95,000km
In Canada.
Any ideas? Hopefully warranty still good.
Tom in PT
Twilight Zone, WA State
2005 Passat sedan - SOLD; 2013 Passat DSG; both purchased new
I'm pretty sure the 2015 Passat came with a 5 year, 60,000 mile (= 96,560 km) powertrain warranty, whichever occurs first. You should confirm that.
Unless you have done something that could give rise to a denial of warranty (like install an aftermarket performance chip , or fail to maintain it per the maintenance schedule), at first glance the warranty should cover repair or replacement of your overheated engine. If your "95,000" miles is approximate you need to be more precise as you are very close to the mileage limit.
thundershorts
west chester pa
sounds like the water pump impeller spun on shaft.
740GLE
NH
Def thinking water pump as well.
ryanmonahan
Thanks folks... it’s been sitting at the dealer now for 3 days and I haven’t heard a thing. I’ll go in there tomorrow morning to see what’s up. It should be warranty. The only issue I can see is that I can’t find my last oil change receipt and it wasn’t dealer... they charge $170.
ryanmonahan
So I stopped at the dealer just now. Didn’t see my car but the service rep
Had some pics. Tensioner on the timing belt seized and belt burnt up. That was the problem that led to overheating. Report is sent in to VW Canada for them to decide if they just do timing job or if they rebuild engine to avoid hassles later if related damage happened when belt broke. Rep says dealer recommends engine rebuild but ultimate call on warranty issues is up VW Canada cause they foot the bill. Anyone have any insight on this?
You will want a new engine. A "rebuild" at the dealer level will result in something you will probably not like. This sounds like a really strange thing, but I guess it could happen. I do not see how a seized timing belt tensioner could cause the engine to overheat. All I could see happening is it rubbing through the belt to a point it failed, then the car just stops, but it would have been at normal temps right up until then.
Now what seems MUCH more plausible, is that the WATER PUMP seized, and since it runs off the smooth side of the timing belt on that engine, it would not have ripped the teeth right off the belt. And THAT would certainly have caused the engine to continue to run, so long as the belt was not yet rubbed through, and get hotter and hotter until either the belt broke and tooefed the engine, or the temp got too hot and tooefed the engine.
Either way, engine is likely beyond reasonable repair. Besides, the cost of the long block will be less than the cost of all the parts and labor to try and fix one. Current list price for a CVCA long bock, 04L-100-033-DX is about 4 grand. That is CHEAP. Valve over to oil pan.
ryanmonahan
Awesome thanks for your advice. I will be talking to them about this.
thundershorts
west chester pa
Wonder if the design of running the wp off the smooth side of belt was to not break the timing belt in the event that happened?
thundershorts
west chester pa
When VW replaces the variable wp under warranty is it replaced with a non variable or is that possible?
I have been told the new replacement ones do not have the collar on them, but the electrical plug is still there. Since there is no feedback for the position, I guess the ECU doesn't care. You'd think there would be some coolant temp monitoring, and if it was flowing 100% all the time it might cause some coolant under temp problems, but I guess that situation doesn't happen or the engines just run so hot anyway that the use of the system is worthless anyway unless you live in Antarctica.
The later VR6s in the T'regs have variable pumps too, but they are vacuum controlled (duty cycled solenoid on the front of the engine) but I have never seen any problems with their collars coming loose.
I suppose the next step will be an electric pump, like the later Prius uses, that costs $700 and randomly without warning dies and tooefs the whole engine just the same. :rolleyes:
740GLE
NH
This. It's the chicken or the egg, and it seems VW never thinks it's the egg to blame.
Hopefully this water pump of the '15 isn't the balanced shaft of the B5 or the cam wear of the PD.
mejpassat
California
2015 Passat TDi (NOS), 2014 passat TDI (Buy back), 2001 Tdi Golf (Gifted to Son)
Well I'm thinking the water pumps are not very good.
Mine was replaced at 35,000 miles due to a loud sound when cold, after warm up it sounded OK. Dealer tore it apart and found that the pump was starting to self destruct.
They also replaced all the tensioner/pullys in there as well.
My car was a NOS so maybe the sitting was the cause?
madmedix
Terra
Passat
That dealer on Lynden Road charged me about 120 too...keep us in the loop on your experience there please :)
ryanmonahan
So my Passat is still in the shop at the dealership. So far I’m told timing belt, water pump, various seals and pulley, they pulled the head and injectors were damaged so new injectors and whatever seals and gaskets are needed to reassemble. I’m at 95,000km so my warranty would have been up in the next 2 months. So maybe it’s a good thing getting all that done now under warranty?
c3kTDi
Undisclosed
2015 Passat
I'd push for a crate engine.
I'd also want them to describe what failed, why, and how that item damaged whatever they think is also damaged and how nothing else is damaged and how you'll be protected for 100,000 km more from any problems they're introducing.
Fixmy59bug
Las Vegas, NV
2015 Passat TDI SE
You can ask all you want, but they wont do that.
They may tell you the tensioner failed and smoked the belt, again like they did the first time. But they can not and WILL NOT tell you "You'll be protected for 100,000 km". That would be implying a 100,000 km warranty and they will do no such thing. The replacement parts come with a 12 month 12,000 mile warranty (I dont know what the km conversion is, maybe 15,000 km?). But no way in hell will they say 100,000 km. And theres no way they can guarantee nothing else is damaged.
