so what do you think? siezed?
i had a runaway in the driveway in nuetrel. black smoke everywhere. I turned car off asv didnt stop it so I put it in 5th and let the clutch up. stopped dead. no loud metal sounds
after: checked oil, down 1/2 qrt. tried to start, just a click from the starter. so I took off hose to egr, good bit off oil in there so I am thinking it was running on the blowby.
I pulled glow plugs and tried to turn the cam shaft nut, but nothing moved. should it move?(I might have been in gear). after that put in 3rd gear and tried rocking the car with a straw down the highest set piston and I feel like it was moving a bit (hoping not seezed). since then I took the battery out and have been beating on the starter. any thoughts what to do next to see if its seezed? video in 5th gear trying to rotate by hand
https://youtu.be/pTS_LeRoTEA
