hahahaha no, just no. a 4 stroke motor shouldn't burn any oil if it's built correctly, does the roof on your house leak an expected amount of water or gas tank leak a certain amount of fuel?
i was just asking here to know if these are known to have bad turbo seals like the PD has cam issues.
I hate to tell you, but oil consumption happens to some degree on ALL piston engines. Some are worse than others, patterns emerge and we see the common culprits (Subarus, anything with a Mitsubishi engine, older non-Ford powered Mazdas, the GM Ecotec DI 2.4L) as well as others.
And some are less common, but variable, like a lot of Toyota engines where one person's 1ZZ-FE Corolla will consume a quart every 1000 miles like clockwork and another person's same year 1ZZ-FE Corolla will go the full 5k mile interval and only be down a half quart.
Also, in many cases, once oil consumption starts, it can have a slight snowball effect where it worsens but perhaps plateaus at a certain point. The driving conditions can play a role here as well.
As I have stated earlier in this thread, you are not the only one that has noted some higher-than-expected oil consumption with a 2015 CR 4 cyl TDI engine. And you will not be the last. It may just be some specific characteristic of this particular engine assembly that lends itself to this, but it still falls within what Volkswagen deems "acceptable". All manufacturers have these pretty lenient allowances for oil consumption. All of them. We recently had a customer "shocked" to hear his new BMW was allowed a 2.5 liter per 1000 miles. And that is almost lock step what it did. It was one of the high performance models.
Some manufacturers have identified and instituted a fix for some excessive oil consumption, but this often involves major repairs or changes to the engine. Subaru has revised cylinder heads with improved valve guide holes in the casting. Toyota has improved piston rings. Isuzu had improved pistons for their V6 engines back when Isuzu was actually selling light duty stuff here. But outside of warranty, virtually NOBODY is going to buck up for these kinds of repairs.
My advice is: keep a stash of oil in your garage, along with a roll of paper towels, and institute a regimen of checking/topping up the oil. It is not a huge deal. I took a Mazda past 400k miles on its original engine, I know what oil use is (1 quart every 100 miles, yes, you read that right). It was running along just fine at 404k miles when I hit a deer at highway speeds.
