Go Back   TDIClub Forums > Picture Gallery/Specs of Members' TDIs > Passat TDI Picture Gallery
Passat TDI Picture Gallery Do you have a Passat TDI? If so write a message here describing it and insert a picture if you have one. If you don't have one on the computer, email me and I'll give you my address and I'll scan it for you. If you need web space for it, email me as well. Please make a short yet descriptive title for your vehicle.
Old October 29th, 2019, 07:10   #496
JFettig
JFettig's Avatar
JFettig is offline   Reply With Quote
Old October 29th, 2019, 08:37   #497
Growler
Got Soot Vendor
Growler's Avatar
Broken Engine mounting?
~Aaron~
Schmutz 2015 GSW S DSG
Schnurren 2001 Golf 2 door.
Old October 29th, 2019, 11:28   #498
JFettig
JFettig's Avatar
Yup! super rigid motor mount combined with a boatload of torque made it crack all over. I welded it up but I should probably figure out what other part numbers fit because this one doesn't appear to be available in NA.
Old October 30th, 2019, 11:38   #499
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
Looks like you have enough room/clearance that you could weld it and add a few gussets to reinforce?
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
Old October 31st, 2019, 10:58   #500
JFettig
JFettig's Avatar
I welded it up and welded it up pretty thick, inside and out. I think having a new one would be best.
Old November 2nd, 2019, 20:04   #501
rotarykid
rotarykid's Avatar
Fuel Economy: 64 .1city @ 30-60 mph/ 52-53 @ 70-85 mph hyway ( 52 to just under 60 normal around town)on LSD
Looks kind of like the Battlestar Galactica at the end of the series when it had been all beat to hell .......
essentially the years of use have done the same thing to that motor mount bracket.
Maybe you can find machine shop that can make a similar piece. Then maybe you can cut the cracked one out clean and weld in a new one , your hand made new one in.....
More diesels than I can list
rotarykid is offline   Reply With Quote
Old November 5th, 2019, 09:36   #502
Kriesel
Kriesel's Avatar
I bet JFettig could make his own engine mount?? haha
My Garage
My Duramax Suburban
Kriesel is offline   Reply With Quote
Old November 14th, 2019, 12:26   #503
JFettig
JFettig's Avatar
I just happen to own 2 4-axis CNC's.....
In reality it's not worth making a billet mount, I'd rather just buy a couple junk yard mounts and reinforce them if it becomes necessary.
Page generated in 0.18226 seconds with 10 queries
[Output: 88.75 Kb. compressed to 76.26 Kb. by saving 12.48 Kb. (14.07%)]
