Kingcodez
I'm looking to start assembling the parts ASAP for an ALH build. The car currently has 220k with 502 injectors, some mild tune, and a bunch of other small mods that I forgot about. The engine has a tick despite new lifters, I plan to visit a guru to track down problem but will most likely buy a new head.
End goal is a quick but reliable engine. I will half-heartedly try to destroy it, most of the time. I plan to build the engine for a 2260VK, but I might stop just short of buying the kit if I'm happy with a maxed-out VNT15 and a new motorcycle. Either way I'll have a 'new' engine to stomp on for another decade.
Build, roughly in order of purchase.
My synchros are old, will this transmission handle the above or should I plan to upgrade to... something?
- New Head, Ported.
- Injectors, anything better than PP764s?
- PD130 Mani w/ simple Meth and N20 hookups for fun. Will prob run water most of time.
- 4-Bar MAP, $5 more.
- Colt Stage 3, any other recommendations?
- ARP Head Studs
- 11mm IP
- FMIC, South Bend Clutch, and Tune.
- Should I bother with valve/spring upgrades 'while I'm in there?'
- Rods, Rosten or Franko6?
- Pistons, what is a logical and reasonably priced upgrade?
- Any ideas on how I can get the bottom end to feel like a teenager again? Would boring to 2.0L or whatever do the trick? Sounds expensive.
- Is a girdle (Eurospec) needed?
