hi guys
sorry for all the newb questions, but being cautious as i'm learning about this car and motor doing things for the first time, etc. i did a search and didn't really find this asked before. i'm wondering if i may have stretched my timing belt, and if so, should i be worried?
finished my first TB install, followed the bentley and the drive-by wire write-up and using the factory tools and OEM parts from idparts
when i first got all the timing components apart i could see the crank seal was leaking. received some sound advise on how to replace the seal, and also to remove the crank sprocket WITH the motor timed/TB installed.
so did the TB job and waited for the crank seal to arrive. replaced it all- belt, all rollers, roller studs tensioner, timing belt, waterpump, etc. all and all seemed pretty strait forward. but when i installed the TB on to the cam sprocket it was REALLY tight getting it ON the cam shaft itself. it look a lot of pulling and effort. when i adjusted the tensioner (the IP bolts were loosened. the cam gear was on the cam shaft, i only hand tightened the bolt as far as i could, but NO wrench) and tightening the belt i did NOT really notice the cam gear or IP gear "turn", as it was described in the bently and writeup. unless it was really subtle amount. i do most of the work at night and sometimes the lighting is not ideal. then turned the motor over by hand a few times, all timing marks still perfectly aligned.
silicone crank seal and crank yank showed up. swapped the new one in. let it sit overnight. next day re-installed the TB belt and it was MUCH easier getting the cam gear on the cam shaft. like the belt had maybe stretched?? with IP bolts loose and cam gear finger tight, again didn't notice the sprockets slip as i adjusted the tensioner. alignment marks are dead center on the tensioner, locked it down. turned the motor over by hand and all aligns as it should. just a little nervous about the belt. that it might have been stretched or looser than it should be? the belt felt SUPER tight before, but maybe it's just as tight now, just no real experience to compare what it should "feel" like.
should i be worried or does this sound normal?
and when pushing on the belt between the cam and IP is there a distance you can measure etc (is the term "deflection"?)?
thanks for any feedback!
Mike
Mike
