FOUND IT! Don't look under "all" passats - look under:
Tricky search feature, that! I looked under "all" passats and found nothing. Knowing our previous poster wouldn't inflame us all for giggles, I decided to check under the 'passenger car' or some such option - the only other option available, and lo and behold up they flew! For your assiduous perusal: Report Date : August 6, 2006 at 10:45 AM SEARCH TYPE : VEHICLE YEAR : 2004 Make : VOLKSWAGEN Model : PASSAT Type : PASSENGER CAR (*remember, if you look under "all", you won't find a one of these!): Results : 7 | All records displayed Make : VOLKSWAGEN Model : PASSAT Year : 2004 Manufacturer : VOLKSWAGEN OF AMERICA, INC Service Bulletin Num : 0505 Date of Bulletin: NOV 07, 2005 NHTSA Item Number: 10018452 Component: EXTERIOR LIGHTING:HEADLIGHTS Summary: VEHICLES MAY DISPLAY VIBRATION OF THE HEADLIGHT DUE TO CLEARANCE BETWEEN HEADLIGHT ASSEMBLY AND FRONT FACIA - EXCLUDING NEW PASSAT. *NM Check to Request Research. Submit below. Make : VOLKSWAGEN Model : PASSAT Year : 2004 Manufacturer : VOLKSWAGEN OF AMERICA, INC Service Bulletin Num : 0517 Date of Bulletin: JUL 14, 2005 NHTSA Item Number: 10016037 Component: SERVICE BRAKES, HYDRAULIC:ANTILOCK:CONTROL UNIT/MODULE Summary: ANTI-LOCK BRAKE SYSTEM (ABS) CONTROL MODULE WARRANTY REPAIR PROCESS. *TT Check to Request Research. Submit below. Make : VOLKSWAGEN Model : PASSAT Year : 2004 Manufacturer : VOLKSWAGEN OF AMERICA, INC Service Bulletin Num : VC Date of Bulletin: MAY 01, 2005 NHTSA Item Number: 10015584 Component: EQUIPMENT:OTHER:LABELS Summary: INSTALL MERCURY LABEL ON VEHICLES REGISTERED IN THE STATES OF VERMONT, MAINE AND CONNECTICUT - ENVIRONMENTAL COMPLIANCE ACTION CIRCULAR. *TT Check to Request Research. Submit below. Make : VOLKSWAGEN Model : PASSAT Year : 2004 Manufacturer : VOLKSWAGEN OF AMERICA, INC Service Bulletin Num : 0502 Date of Bulletin: JAN 14, 2005 NHTSA Item Number: 10012457 Component: ELECTRICAL SYSTEM Summary: DIAGNOSTIC TROUBLE CODE (DTC) P1603 (18011) STORED IN DTC MEMORY. *TT Check to Request Research. Submit below. Make : VOLKSWAGEN Model : PASSAT Year : 2004 Manufacturer : VOLKSWAGEN OF AMERICA, INC Service Bulletin Num : 004 Date of Bulletin: NOV 09, 2004 NHTSA Item Number: 10011567 Component: ENGINE AND ENGINE COOLING Summary: ENGINE COOLANT TEMPERATURE (ECT) SENSOR. *TC Check to Request Research. Submit below. Make : VOLKSWAGEN Model : PASSAT Year : 2004 Manufacturer : VOLKSWAGEN OF AMERICA, INC Service Bulletin Num : 0419 Date of Bulletin: OCT 27, 2004 NHTSA Item Number: 10010537 Component: ENGINE AND ENGINE COOLING:EXHAUST SYSTEM:EMISSION CONTROL Summary: UPDATE PROGRAMMING - EVAPORATIVE EMISSIONS (EVAP) SELF-TEST REVISION. *TT Check to Request Research. Submit below. Make : VOLKSWAGEN Model : PASSAT Year : 2004 Manufacturer : VOLKSWAGEN OF AMERICA, INC Service Bulletin Num : 0403 Date of Bulletin: OCT 01, 2004 NHTSA Item Number: 10010539 Component: ENGINE AND ENGINE COOLING:ENGINE Summary: VALVE COVER, DIAGNOSING OIL LEAKAGE FROM GASKETS. *TT ************************************************* NOW I *am* wondering if the fix is just for emissions (ULSD intro) or what. BTW: Anyone know the process for upgrading my AT to 1134 sports mode? After I take my '04 in for these TSB's I'd like to do it! Deann ********
