Was a fordie
I am buying soon(within the next week) a 1994 T100/([pre tacoma) that has a shot motor... head gasket cracked on it. I will be ripping out the motor and putting a VW Jetta TDI 1.9 L turbodiesel motor into it. I planning to do it as my hobby car to tinker on. I'm getting it for a really good price..
the immediate plan is first to rip out the old motor... and junk it for scrap....
then
Replace
Shocks (better shocks and suspension components), upgraded brakes,new fuel lines, drop the fuel tank and clean out any gasoline residue in the tank, rip out the stock gas filler neck and find off ebay a diesel fuel filler neck with the wider diesel truck pump neck and get a diesel fuel cap for inside the fuel door... Mount the Diesel fuel filler neck in place of the stock one.
leave tank aside until I install the engine sometime next spring.....
Replace all brake lines with steel cables, replace two rusted fender panels with 2 new primered body panels (that will be panted at a later stage once the project is finished)
Replace all Wheel bearings, bushings, control arms, etc....
Install a stage 5 clutch kit and basically rebuild the transmission and make sure everything is fine with the transmission...
Other things, i am still researching, but I am also going to be adding a VW specific OBD port under the dash to hook up to the ECU computer so I can pull engine codes in the future and so I can tune the engine with the aftermarket MALONE tuning that is out there for the VW engines.
Next spring, after i get my taxes back, i will be looking for an insurance write-off wrecked salvage VW JETTA TDI 1997-2005 year model with the VE-Injection TDI engine. (Ahu,ALH or maybe BEW engine code)
I will use that salvage car wreck to pull wire harnesses, fuel pumps, engine, turbo (to resell),and any other parts I will need from that car to go into this project. I will also take the Jettas fuel tank with and use that as an aux tank in the truck. So I will have to get additional fuel pumps to put in both this tank and the t100's tank., I will set up one tank as a master and the other as an aux. tank that I can switch between.
Once I get all the parts and goodies i need out of the wrecked jetta, i'll haul it off to get scrap money for it (with a relatives truck)
I will then get the engine ready for install and put a stage 2 turbo on it, (a larger VW specific turbo) a Garret VNT 17/22.. the stock turbo is a bit smaller. I will then have the engine tuned to either a Stage 4 or stage 5 tune. I will also install better injectors and a 3 BAR Map sensor.
planning to shoot for 170 hp
I am also going to make it so I could run straight vegetable oil if I wanted to as well or run B5-B100 biodiesel.
I also will be taking the entire muffler/cat convertor out and putting in a High Performance Diesel CAT for all VW TDI's (2.5 or 3 inch) Magnaflow/easter catalytic.
I will then install a dual semi truck style exhaust coming up through the bed.
also, as i am an amsoil dealer.. I will be putting nothing but amsoil in the truck for fluids, Engine oil, severe gear oils, transfer case oils, clutch fluid, brake fluid... and coolant...
has 216,000 miles... dead engine with cracked head...he wants 350..but willing to negotiate.. I'm going to try for 200 cuz.. 1. I got to rent a uhaul trailer and borrow my gf's brother in laws truck and pull it about 40 miles to a 100 miles depending on where I'm going to leave it sit until I get some parts together and start working on it... (relatives letting me keep there and work on it cuz I can't work on stuff at my apartment) <--I might be moving soon so then I'l have a garage to work on it.
It's been a idea in my head for a while now...just hoping the pieces fall into place to make this happen
then
Replace
