mannytranny
Do I have to have the engine running in order to have the seats heat up?
Anyone know!?
Anyone know!?
I don't know if it's my misperception, but it seems when I start out on a cold morning that the seats don't really come into their heated glory for about ten minutes; about the amount of time it takes me to get to the highway. It's almost as if the battery has to recover its charge, from the effort of turning over the engine, before the electrons can move on to a secondary use like heating backsides. It will feel a little warm but then I'll get a sudden burst of heat as if a current limiter shut off.mannytranny said:Do I have to have the engine running in order to have the seats heat up?
Anyone know!?
Could be the heaters warming up... I think they are slow. Try getting on the highway first, then firing up the butt-toaster. I dont remember what the outcome of that was, but i think it took just as much time to warm up on a warm engine.RT1 said:I don't know if it's my misperception, but it seems when I start out on a cold morning that the seats don't really come into their heated glory for about ten minutes; about the amount of time it takes me to get to the highway. It's almost as if the battery has to recover its charge, from the effort of turning over the engine, before the electrons can move on to a secondary use like heating backsides. It will feel a little warm but then I'll get a sudden burst of heat as if a current limiter shut off.
I'm in the same situation than you. In fact, I prefer not to use it when I go to work since the ride isn't so long (around 10 miles) and I don't want to drain the battery especially when it does not have a long time to recharge itself.I always shut them OFF prior to glow time and cranking the starter when its COLD.
and why would you ever want to do this? i see you're in california... i can't imagine any situation where you would turn on the seat heaters on w/o having the car running in the first place. are you trying to save fuels?mannytranny said:Do I have to have the engine running in order to have the seats heat up?
Anyone know!?
I have no issues with useing them on any length trip, although my usual commute is 40 miles, just never prior to glowing and cranking when its COLD. The TDIs have a high capacity alternator, never had a problem keeping the battery charged.Nico3d3 said:I'm in the same situation than you. In fact, I prefer not to use it when I go to work since the ride isn't so long (around 10 miles) and I don't want to drain the battery especially when it does not have a long time to recharge itself.
Same here. I don't leave the seats on when the glow plugs are going but I have no real concern about using them once the engine is running. It takes about ten miles before I feel them getting warm though so it might be pointless to use them on a trip that long.jettawreck said:I have no issues with useing them on any length trip, although my usual commute is 40 miles, just never prior to glowing and cranking when its COLD. The TDIs have a high capacity alternator, never had a problem keeping the battery charged.
Both seats are run through a single 15 amp fuse. So max of 7.5 amps per seat. The seats run at full current till they reach their desired temp, then run at a reduced duty cycle to maintain that temp. So 7.5 amp draw is defenitely a worst case scenario.Funguy said:Same here. I don't leave the seats on when the glow plugs are going but I have no real concern about using them once the engine is running. It takes about ten miles before I feel them getting warm though so it might be pointless to use them on a trip that long.
Still I wonder how long, roughly, the battery (engine off) could run one seat and still have reasonble power left to glow and crank?????
No blame Bro. I asked for it. Makes sense. There were times in the past were I could have used a warm seat while waiting for my kids and the like. Now they are about grown but who knows I might find my butt sitting in the cold waiting for somebody one day and put your one hour to the test.david_594 said:(and dont blame me if you try this and your car is dead after an hour)
to cycle on is to turn on and then turn off. i believe the glow plugs stay on for as long as the light on the dash. im not sure about coolant.Funguy said:So if I leave the key on, without the engine running the glow plugs and coolant plugs will continue to cycle on and kill the battery?????
I thought the glow plugs stay on after the dash light goes out until the engine reaches a certain temperature???????SoaceMunky said:to cycle on is to turn on and then turn off. i believe the glow plugs stay on for as long as the light on the dash. im not sure about coolant.
