LightningBug
New to this forum, veteran on other VW forums. Mother-in-law recently passed and her '02 Beetle TDI was sitting in the garage for a while. Family would charge the battery and bring it out into the driveway to idle or take it on short jaunts around town once in a while. Decided that I would "clean things up" and drive it to work (25 min one way highway) once in a while to keep things moving. Charged battery, changed BLACK air filter, changed oil, fresh fuel with a can of "sea foam" and a basic once over. Starts great but the check engine light comes on shortly after starting. Auto Parts Place put the computer on it and it shows "cylinder 3 injector circuit faulty". (Can't remember if they said #3 or #4, but 4 doesn't make much sense.) I can fix this, after all, I'm an electronics tech! Pulled the engine cover off and.... no wires to be found. (except one on the #3 injector.) Searched this forum and learned about changing nozzles. Easy. Didn't change them yet, but I did pull them apart and clean and check and everything went back in no problems. Everything looks great, no obvious wear.
Everything is back together and the check engine light is still on and there is still no power when you step on the pedal. Now I don't expect this thing to drop me back in the seat like my "slightly" modified '74 Beetle, but there should be something. When it finally gets up to speed, you can feel the power coming and going when driving on a flat at a steady pace.
I'm a bit new to these diesel jobbers but with a little help I should be able to figure this thing out. Also has a problem shifting, (automatic) but I think that is unrelated and will save that for a later discussion.
Smokes only slightly on startup, clean after a minute. No foul odors, idles smooth.
Help?
Being slightly experienced with these forum things, I try and give as much info as possible but I'm sure there will be some questions.
Help?
