Old October 22nd, 2016, 03:55   #31
Pieman
Pieman's Avatar
Originally Posted by Bobby Singh View Post
Try bosch HW: 8E0907401AL
VW Software: 8E2910401D
Thanks.
Audi A4 Avant B8 2.7 TDi 262bhp 440lbft.
Audi A6 Avant C6 3.0 TDi ASB in progress.....
Pieman is offline   Reply With Quote
Old October 22nd, 2016, 03:57   #32
Pieman
Pieman's Avatar
Anybody know if its possible to fit the Hella BV50 actuator on a S200V??
Old October 22nd, 2016, 07:08   #33
hatemi
Done that. Not optimal since you need to change the goemetry and the lever on the actuator is some weird metal that explodrs to flames when you weld it...
Lähetetty minun D5503 laitteesta Tapatalkilla
www.tdituning.fi
hatemi is offline   Reply With Quote
Old October 30th, 2016, 08:04   #34
Pieman
Pieman's Avatar
Lol.
Sounds like some cheap Chinese metal that I've used recently!!
Old February 17th, 2017, 09:06   #35
Bobby Singh
Bobby Singh's Avatar
TDI(s): Audi 3.0 TDI
BV50 to 2260 project
Well I spend some time on this project and I managed to get the ecu to control the Hella actuator. However, the immo was blocking issue for me. I spoke to a few people including VCDS about adapting the immo 4 data but no joy.
All the guys to whom I’ve spoken to wanted paying regardless of success or not – I can understand this but there is only so much time and money that can be thrown at this.
Here is what I did:
Got a 2.7 V6 engine (they come with a 1756vk – hella) harness and started work to transfer it to the BV50 car.
But I noticed some of the wiring under the ECU were different –
i. Glow plug relay in 2.7 was 40amp and in 3.0 70amp
ii. Red plug had a wire missing
iii. Black connector was different type in the 2.7 loom
Decided to reverted back to stock and take the relevant wires from the 2.7 loom and merge them to the BV50.
Loaded flash, mpc and e2p from the 2.7 to the 3.0 and attempted to do a vcds actuator test:
Then it was a case of trying to adapt / port the immo data from the target car but couldn’t make it happen.
I tried immo off and the car ran etc but had SAFE on the dash.
To physically mount the 2260 would not be too difficult. I would take 059145722M as it looks to be a close match for the BV50 downpipe. You’ll need the 2260 Y collector and return line.
You have all the information if someone wants to continue.
BSR
Audi A4 3.0TDI B8 - 440hp/900nm...
Bobby Singh is offline   Reply With Quote
Somebody PLEASE do a direct PWM turbo controller already!!! TDIMeister TDI Power Enhancements 124 March 24th, 2015 15:09
What is the ID & OD of the turbo outlet on the 2260vk turbo pls? tothemax TDI Power Enhancements 3 October 21st, 2012 10:59
FS: BV50 Turbocharger 2260vk equivalent $350 Locosmotion Private TDI Items for Sale/Wanted 9 October 29th, 2011 17:28
FS: BV50 Turbocharger 2260vk equivalent (Located in Utah) Locosmotion Private TDI Items for Sale/Wanted 17 October 7th, 2011 13:50
kkk BV50 turbo repair kit? imkbm67 TDI Power Enhancements 3 May 7th, 2011 00:45
Copyright - TDIClub Online LTD - 2014
© 1996 - 2015, All Rights Reserved
Page generated in 0.12614 seconds with 12 queries
[Output: 73.60 Kb. compressed to 65.26 Kb. by saving 8.33 Kb. (11.33%)]
