Torxie
We purchased a used 2012 Q7 TDI with 61k miles about two months ago. Everything was running well until we had the windshield replaced. Since then, I have had repeated wiper malfunction indicators. First time it happened, I double checked that everything was securely connected. Indicator would go away for a couple days only to return again. Yesterday I ran a complete scan on VCDS and found five fault codes. I should also mention that since the replacement of the windshield the blow motor has also been intermittent, which I find odd and probably just coincidental. Below are the faults that we found with the scan. Any help would be greatly appreciated.
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AH
Component: KLIMA 4 ZONEN H15 0070
Revision: 00---026 Serial number: 00000000281155
Coding: 0004A036
Shop #: WSC 31414 790 00001
VCID: 25170C98C5E3BC6F99F-8070
1 Fault Found:
01273 - Fresh Air Blower (V2)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 3
Fault Frequency: 7
Reset counter: 193
Mileage: 102105 km
Time Indication: 0
Date: 2019.08.22
Time: 12:26:17
Freeze Frame:
Temperature: 31.0°C
Speed: 0.0 km/h
(no units): 70.0
Load: 0.0 %
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 AH HW: 4F0 907 279 D
Component: ILM Fahrer H31 0400
Revision: 00000000 Serial number: 4F0907279
Coding: 0039123
VCID: 6FBB2EB05B9FB63F233-803A
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00150059
Shop #: WSC 31414
Subsystem 3 - Component: Fehler Lin-Slave 01
2 Faults Found:
00061 - Footwell Lights
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00110111
Fault Priority: 3
Fault Frequency: 1
Reset counter: 177
Mileage: 101692 km
Time Indication: 0
Date: 2019.08.18
Time: 15:18:00
00908 - Control Module for Wiper Motor
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 13
Reset counter: 158
Mileage: 101692 km
Time Indication: 0
Date: 2019.08.15
Time: 18:58:00
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 AB
Component: KLIMABETAETIGUNGH06 0060
Revision: 00---010 Serial number: 00000030197039
Coding: 0000006
VCID: 688945AC7E716107629-803C
1 Fault Found:
01320 - Control Module for Climatronic (J255)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 146
Mileage: 102105 km
Time Indication: 0
Date: 2019.08.22
Time: 12:26:22
Freeze Frame:
ON
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 H HW: 4L0 907 289 H
Component: Komfortgeraet H10 0110
Revision: 0110 --- Serial number: 01510216010000
Coding: 3569693
VCID: 3537DCD87943CCEF29F-8060
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H05 1501
1 Fault Found:
01697 - Footwell Lighting; Rear Right (W46)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 47
Mileage: 42410 km
Time Indication: 0
Date: 2011.03.31
Time: 00:44:23
Coding: 0004A036
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 193
Mileage: 102105 km
Time Indication: 0
Date: 2019.08.22
Time: 12:26:17
Freeze Frame:
Temperature: 31.0°C
Speed: 0.0 km/h
(no units): 70.0
Load: 0.0 %
Coding: 0039123
Coding: 00150059
Shop #: WSC 31414
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 177
Mileage: 101692 km
Time Indication: 0
Date: 2019.08.18
Time: 15:18:00
Freeze Frame:
Fault Priority: 1
Fault Frequency: 13
Reset counter: 158
Mileage: 101692 km
Time Indication: 0
Date: 2019.08.15
Time: 18:58:00
Coding: 0000006
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 146
Mileage: 102105 km
Time Indication: 0
Date: 2019.08.22
Time: 12:26:22
Freeze Frame:
ON
Coding: 3569693
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 47
Mileage: 42410 km
Time Indication: 0
Date: 2011.03.31
Time: 00:44:23
