Old July 4th, 2015, 21:28   #16
Revpeach
TDI(s): 2012 Jetta
Fuel Economy: 43
Mine started random long cranks about a week before my battery quit. Showed 12V but had no amps and would not take a charge. Battery was only 3.5 years old but I have 82k miles on it. New battery and back to almost instant starts.
Revpeach is offline   Reply With Quote
Old July 4th, 2015, 21:39   #17
jasong70
Was it random or all the time? Funny when I immediately shut the car off it restarts fast. If the battery was dying, wouldn't it do the long crank?
jasong70 is offline   Reply With Quote
Old July 5th, 2015, 06:11   #18
Revpeach
TDI(s): 2012 Jetta
Fuel Economy: 43
There seemed to be no pattern. I first thought it was a fuel problem from letting the car sitting and not being used. Then the long cranks would show up while being daily driven. My unscientific 2 cents worth is that as the battery dies it cannot provide sufficient current to all the glow plugs thus creating the hard start.
Old July 5th, 2015, 20:44   #19
Joel_S
My 2010 jsw does this randomly. No pattern to it what so ever. My battery still tests good, and there's no pattern to it. My car sits for months at a time because I daily drive my M5 now (for some odd reason I've been enjoying the 16mpg instead of my 45+ in the Jetta) and it started today after sitting for 3.5 weeks. I drove it across my parking lot at my apt and turned it off. When I restarted it it was fine. About an hour and a half later, long crank before start. I've always wondered if it was just me.
Joel_S is offline   Reply With Quote
Old July 6th, 2015, 06:18   #20
vwman2
I want to say the batt was replaced 2 years ago with a OEM. I do see the batt light on when im cranking but I think it always is till it kicks over. doesnot crank slow...
vwman2 is offline   Reply With Quote
Old August 28th, 2019, 06:25   #21
97B4TDi
97B4TDi's Avatar
Fuel Economy: 46-52
I know I am resurrecting an old thread but did anyone track down their cause to this?
Just picked up a '13 JSW a month ago and I've experienced a few "long cranks" with no pattern as well.
Thank you!
'13 Sportwagen: 58,XXX Miles - 3M Automotive Window Film Ceramic Series - VLT 30%
'97 Passat:
321,XXX Miles, Malone Eco Tune, Bosio PP 502, FAT/KFC Mod, Ventectomy, DRL Kill, 1000 Mile Club x3 / Auto Trim DESIGN
97B4TDi is offline   Reply With Quote
Old August 29th, 2019, 04:58   #22
Matt927
Matt927's Avatar
TDI(s): several
Mine will still have a long crank, first start of the day only. Two taps on the throttle when the glow plugs are cycling before hitting the starter button again, the car fires right up.
Matt927 is offline   Reply With Quote
Old August 30th, 2019, 14:06   #23
ksing44
There was another thread and a video about this for the first start of the day.
Increased Cranking Time When Starting
DiagnoseDan - VW golf 2.0TDI EA288 long crank diagnosis
2010 Golf TDI - (BGM), 4-Dr, 6-M, Sunroof, Xenon, Dynaudio, Nav (RNS-510), Euro light switch, 9W7 BT, R Tinted LED Tail Lights, Monte Carlo 17" x 7.5" ET47 Wheels, 235/45/17 Tires, P3Cars Digital Interface, Sonniboy sunshades, CP3 HPFP: 11/8/2016 @139,848 miles, The Fix: 9/27/17 @153,289 miles
Flickr slideshow
ksing44 is offline   Reply With Quote
Old August 30th, 2019, 17:28   #24
97B4TDi
97B4TDi's Avatar
Fuel Economy: 46-52
The EA288 video doesn’t apply to our cars we dont have the VVT system the 2014 cars do.
'97 Passat:
Old August 31st, 2019, 14:32   #25
ksing44
Originally Posted by 97B4TDi View Post
The EA288 video doesn’t apply to our cars we do. It have the VVT system the 2014 cars do.
Thank you for the clarification!
My car really isn't bad at all. It starts instantly during the day, but the first start can take one or more extra spins of the starter. I've decided to not let that bother me. My 2010 Golf TDI has been and continues to be a wonderful car!
Flickr slideshow
Old September 1st, 2019, 09:34   #26
Matt927
Matt927's Avatar
TDI(s): several
My view as well.
Old September 2nd, 2019, 16:51   #27
ricohman
My new to me 2013 wagon did this as well.
A new battery solved the issue. The old battery tested well. But at 5 years old it must have been on its last legs.
ricohman is offline   Reply With Quote
Old September 30th, 2019, 21:14   #28
Jaxon
I'm having a very similar issue with my 2012 Golf Sportwagen A6. Car has 292,000 kms on it.
I bought it a year ago, and it would randomly take a long time to start, for the first start of the day. Didn't matter if it was +20 or - 20. Car always started. Maybe 1 in 20 times would require extended cranking.
This spring it got a lot worse. Now it's 1 in 2 first starts of the day.
I always let the glow plugs cycle. The car will spin and spin and spin. I stop, key off, cycle plugs and try again. Sometimes I need to do this a third time, car will start, run rough for a couple seconds, then works perfect. I have tried just spinning it over until it starts, eventually the car starts flashing low oil pressure on the dash. I don't think it's fuel draining back because I left the car parked for 6 weeks this summer while I drove my other car, and when I got back to it, the battery didn't have much juice, but it still started up right away after a few slow cranks. Car has NOT had the fix, and the condition of the DPF is unknown - car seems to run good, and gets acceptable fuel milage.
Thoughts?
-2012 Golf Highline wagon - project car
-2004 Jetta TDI 5-speed wagon, 360,000 K
-2008 Silverado 2500HD Duramax diesel
-2002 Trans Am WS6 convertible
-1970 Pontiac Catalina
Jaxon is offline   Reply With Quote
Old October 4th, 2019, 22:02   #29
travis45
travis45's Avatar
Does it look like this?
https://youtu.be/CCtTNUhlS1Y
14 Sportwagen. 267hp last time at the Dyno.
travis45 is offline   Reply With Quote
Old October 5th, 2019, 19:56   #30
super1
TDI(s): none
Thoughts?
You look at this video?
https://youtu.be/DXvHdmq0reA
super1 is offline   Reply With Quote
Random long crank issue slamhouse TDI 101 3 April 29th, 2012 13:13
97 Passat TDI - Random Stalling, Won't Shut off with key -LONG- CrazyShaneD VW MKIII-A3/B4 TDIs 8 February 16th, 2012 18:35
Will not crank - Random Kibbs VW MKIV-A4 TDIs (VE and PD) 4 April 3rd, 2011 14:36
Random Crank, no start, no Glowplug light on key insert honesttussey TDI 101 8 May 27th, 2007 08:29
Long cranking when warm (random) Luc Angiolelli VW MKIV-A4 TDIs (VE and PD) 6 February 15th, 2001 01:55
Page generated in 0.18614 seconds with 11 queries
[Output: 131.32 Kb. compressed to 110.17 Kb. by saving 21.15 Kb. (16.11%)]
