Johnny_tdisport
Hi
in my ASV 038906018FB ECU, i was running with the 051c sensor map non calibrated on the ecu tune(2600 map linearization) and boost map at 2525mbar, around 1.9/2bar boost pressure so as in the log with vcds 011 field can read the boost.
now i'm using the 059 4bar map sensor, and i intent to do the map linearization to 4000. but if i do that, in the vcds it will only read a max o 2600bar correct?
my question is if ist possible to change or adjust/tune file to let the vcds read more up to the 4000mbar? if yes,how?
thanks
thanks
