Capture1
Just got a quote from the dealer and it is between $300 to $350 to change the DSG transmission fluid. The 40,000 chnage interval is in an insert to the Beetle manual and not in the normal maintenance section
From a previous quote "also dsg trans fluid change should be done at 40k (note needs to be done by dealer) with vag-com and special type trans fluid." Why does it need to be done by the dealer? Why do I need a vag-com just to change the transmission fluid? Can anyone shed some light on the special process required to change the DSG transmission fluid. I normally change all the tranny fluid and filter on my cars but I am a little worried after hearing that you need the vag-com to do this.
Has anyone actually done this themselves?
Thanks.
Thanks.
