thysmar
low oil pressure light came on when first started, checked with mechanical gauge: no pressure. Gear that drives vacuum pump turns when cranking, oil pump drive shaft where it meshes with vaccuum pump appears OK. over 300K on this car, could the pump be too weak to pick up the oil in cold weather ?
This happened once before at startup and a shot of the throttle made the ligth go out.
What is involved with access and removal of oil pump?
Any help appreciated
