The Critic
No clue
Its a PD Passat...that's all I know...so I'm guessing 2.0? Correct me if I'm wrong.
This is kinda what I was looking for the Castrol 505.01. However, not sure what all these numbers mean. Does it look like this stuff will hold up for 10K miles? (BTW, didn't feel like sifting through the other 20 pages....and you wouldn't either.)thermographer said:Results of oil sample, November 27, 2005. 4550 miles, Castrol 505.01. 97219 total miles.
The short turn around on the oil was due to the first OA of 230ppm of Iron. This sample was taken using oil sample pump.
Aluminum 6
Calcium 3169
Chromium 1
Copper 3
Iron 47
Lead 1
Magnesium 42
Molybdenum 2
Nickel 1
Phosphorus 862
Potassium 2
Silicon 3
Sodium 2
Tin 0
Vanadium 0
Zinc 1099
Water, Antifreeze, and Fuel all negitive. V100 is 13.0
Oil installed during this sample/oil change was Elf 507.
dhdenney - don't do it. at least not during the warranty period, because Bardahl is not VW 505.01 approved.dhdenney said:Thanks for the reply. I only have about 5800 miles on my car total so my wear metals would naturally be much higher. I just wanted to make sure that the Castrol could hang on for the 10K interval once I get the next change at 10K miles. I am considering switching to Bardahl XTC 5w40. It's VW 505.01 compliant and says it's 100% synthetic. I can save over $0.50 a liter if I count the tax I would pay at the dealership.
i think it's cool to start trending the numbers early because it's fun to see the wear metals drop hard during the first 5 or 6 OCIs.dieseldorf said:I really don't know why people are spending $$$ on sampling oil on a brand new engine....the values are likely to look zany.
Agree: All this does is check to see how well the shop cleaned the parts. As a machinist I can inform you the only units receiving an oil flush are hydraulic assemblies. That's why VW calls for a couple of short oil change intervals on the engines.dieseldorf said:I really don't know why people are spending $$$ on sampling oil on a brand new engine....the values are likely to look zany.
Who says the Bardahl isn't 505.01 approved?SUNRG said:dhdenney - don't do it. at least not during the warranty period, because Bardahl is not VW 505.01 approved.
VW. this is the list of all oils that have been 505.01 approved by VW.dhdenney said:Who says the Bardahl isn't 505.01 approved?
I 100% agree that the Bardahl doesn't appear on this list. However, I don't think they would make a claim such as that if it were not compliant.SUNRG said:VW. this is the list of all oils that have been 505.01 approved by VW.I'm not trying to be contrary, I'm just looking out for you and your PD.
It is engineered to surpass Ford M2C917, Mercedes-Benz 229.1, Volkswagen 500.00 / 501.00 / 502.00 / 505.00 and 505.01 specifications
Bardahl guarantees that its XTC 5W-40 100% Synthetic Motor Oil is formulated to meet or exceed the manufacturers' vehicle motor oil specifications for most domestic and imported gasoline and diesel engines; API SJ/CF, ACEA A3/B3, BMW, M-B 229.3, Ford WSS-M2C917-A, Porsche, GM (SAAB/OPEL), VW 502.00/505.00/505.01. Therefore, Bardahl will pay for parts and labour deemed reasonably necessary to repair damage to engines if it can be demonstrated that the damage was caused solely and directly by a breach of this warranty.
there are no, zero, 100% fully synthetic 505.01 approved oils. in addition, 502.00/505.00/505.01 is not a VW approval sequence. no oil in the world is 502.00 and 505.01. the sequence is 500.00/505.00/505.01.dhdenney said:I 100% agree that the Bardahl doesn't appear on this list. However, I don't think they would make a claim such as that if it were not compliant.
this issue is long since dead guys. i actually started this thread in September of 2004 regarding this exact oil and 505.01. please delete your "XTC is 505.01" posts from this thread so newbies scanning this thread do not mistakenly think it is 505.01 approved.Maybe just lag between certifications being granted and the list being "published" (it's dated June 23, 2005).
you're kidding right? what about the search engine?fitzski said:Calm down now SUNRG... if you'd responded with those references initially, it would have saved some obvious aggravation. Since you didn't, we had no reason to believe it had been covered before.
i'm not asking you to remove your posts because you've broken a rule. i'm asking out of consideration of newbies and others that may not read beyond it enough to discover it's incorrect information.I will not delete my post; if a moderator deems it necessary, so be it. I see nothing against the rules in my post
Bardahl saying it is compliant and VW saying it is compliant are worlds apart.dhdenney said:I 100% agree that the Bardahl doesn't appear on this list. However, I don't think they would make a claim such as that if it were not compliant.
excellent choices!I'm just gonna stick to Impex and TDIparts.com
spicy - i really hope your dealer is cool, because this is a known issue. i'd call first thing in the morning. tell the dealer that your used oil lab analysis showes that glycol/antifreeze was present in the oil change interval that began at 45k and went to 53k? and, mention that this is a known issue and the EGR cooler is likely the cause.spicy_red said:SUNRG check your PM - just received some bad news. Oil Sample at 53k tested positive for glycol. Can't upload onto photos section for some reason so I'll need to email it to you.
Will need to resample pretty quick - am driving 2400kms over xmas, will pull sample when I get back. Just went and checked the coolant reservoir and guess what...? It's down, not my much (at lowest notch).
FYI: the latest sample is w/ Motul, car now running Elf.
