dqa
Waited too long to replace rear brake pads - was unable to slide my Harbor Freight caliper reset tool into position. With a little effort I used the wrench from my angle grinder to rotate the caliper. I was then able to get one knob of my caliper tool in place, but the other knob stayed firmly on the outer edge of the caliper piston. Good enough to rotate and apply a little pressure, but because there was not enough room for the pin and its disc to clear the far side of the caliper piston, it couldn't rotate any further clockwise. Meanwhile, the caliper reclaimed a bit of the slack space, so I couldn't wiggle the tool back out. Trying to turn the tool counterclockwise just tightens it as the caliper piston extends out.
Now I can't seem to free my tool from its jam. Suggestions?
