evanbatterman
I recently bought some chips for my b 4 passat tdi, and someone told me to do the hammer mod, but I cant find any thread. could someone explain what it does and how it works?
Tap tap tap, not hit hit hit.Overfuelin5spd said:Does Robert Bosch know about people hitting his pump with a hammer??
Why would the pump manual take into account those running larger than factory nozzles in certain specific situations? (there are a lot of things that aren't in any manual)Overfuelin5spd said:I read the Ve pump manual from Bosch, no where in it does it state
" If the computer cannot automatically make the adjustments on its own you must hit it with a CLAW hammer."
Corporal, would you turn to the page in this book that says where the enlisted men's mess hall is?Overfuelin5spd said:I read the Ve pump manual from Bosch, no where in it does it state
The effect is very pronounced. Get it too low (like below 1), and the pump can outrun itself (or so I've heard). It usually is used to adjust the IQ where you want it so smoke and drivability are both manageable. You can only change the IQ so much with adaptation in VCDS, this helps go further should you need to based on your current, and non stock, hardware. You measure the distance by watching the IQ change in VCDS preferably on a laptop perched up in the engine bay as you gently tap with a soft mallet, or even prop a piece of wood on the pump head. It's very easy, you just need the special triangle bit to loosen that one bolt.FlashT said:How pronounced is the effect of this modification (if larger diameter injectors are the only variable)? Also, if the pump is adjusted too much in either direction, would the integrity of the pump be compromised? How would one go about measuring the distance(either left or right) that it needed to be tapped?
Precisely my thoughts.Got Bearings? said:Corporal, would you turn to the page in this book that says where the enlisted men's mess hall is?
Lt. Kaffee, that's not in the book, sir.
I don't understand, how did you know where the enlisted men's mess hall was if it's not in this book?
I guess I just followed the crowd at chow time, sir.
No more questions.
LMAO, I can't remember what movie that's from.Corporal, would you turn to the page in this book that says where the enlisted men's mess hall is?
No more questions.
In order to adjust the IQ, you WILL need the triangle pump socket. Trust me, there is no way to loosen that tight little SOB without screwing up the head of the bolt or the top of the injection pump.
