OK- I got all the wires mended, I do believe. There definitely seemed to be water coming in around cabin air filter housing. I pulled that and replaced crummy old gasket with a fat bead of roofing black jack. Also, my drain holes under the batter already have the rubber pieces pulled out, and doesn't seem that area is flooding. Also, re-fixed the 2 holes in floorboard where a rock busted through it a few years back. So hopefully no more water entry.
My glove box is still off because I want to be able to monitor the wires for a bit while I drive around to periodically feel if any are getting hot.
When I started up the car, the airbox light is on and a notification saying something like air bag fault. Then after that message it says the message that was displayed when first started getting smoke in cabin:
Emissions Workshop!
And a flashing glow plug light.
Also, my ABS light is still on, which came on when I was getting smoke in cabin as well.
When all of this first happened, I tried to hook up VCDS to scan, but it would not let me and said there was a ground fault. However, now I am all good, and was able to run a scan. Here is what it said:
Sunday,24,March,2019,21:33:50:58345
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.1.0 (x64)
Data version: 20190114 DS296.0
www.Ross-Tech.com
VIN: WVWVE63B94E275110 License Plate:
Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
VIN: WVWVE63B94E275110 Mileage: 369400km-229534miles
Address 01: Engine Labels: Redir Fail!
Part No SW: 038 997 016 K HW: 028 101 114 5
Component: RC s02G EDC G000SG 0092
Revision: 12345678 Serial number: XXXXXXXXXXXXXX
Coding: 0000072
Shop #: WSC 66565 257 00032
VCID: 264277BC9204E47A87-5140
3 Faults Found:
19460 - Relay for Low-Output Preheating of Coolant (J359)
P3004 - 000 - Open or Short to Ground
Freeze Frame:
RPM: 0 /min
Torque: 150.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Bin. Bits: 00101100
Load: 11.4 %
Bin. Bits: 10011000
19462 - Relay for High-Output Preheating of Coolant (J360)
P3006 - 000 - Open or Short to Ground
Freeze Frame:
RPM: 0 /min
Torque: 150.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Bin. Bits: 00101100
Load: 11.4 %
Bin. Bits: 10011000
16486 - Mass Air Flow Sensor (G70)
P0102 - 000 - Signal too Low - MIL ON
Freeze Frame:
RPM: 924 /min
Torque: 40.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.70 V
Bin. Bits: 00001100
Mass Air / Rev.: 850.0 mg/str
Mass Air / Rev.: 0.0 mg/str
Readiness: 1 1 0 0 1
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 G
Component: ABS/ESP front 3428
Coding: 04255
Shop #: WSC 05311
VCID: 254070B0BF02EF628E-5140
3 Faults Found:
18265 - Load Signal
P1857 - 35-00 - Error Message from ECU
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
30-10 - Open or Short to Plus - Intermittent
00285 - ABS Wheel Speed Sensor; Front Right (G45)
30-00 - Open or Short to Plus
Part No: 1C0 909 605 C
Component: 09 AIRBAG VW61 04 0003
Coding: 12345
Shop #: WSC 05311
VCID: 24466DB4B438166A99-5124
5 Faults Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
00591 - Seat Belt Switch; Driver (E24)
32-10 - Resistance Too High - Intermittent
00592 - Seat Belt Switch; Passenger (E25)
32-00 - Resistance Too High
01217 - Side Airbag Igniter; Driver Side (N199)
01218 - Side Airbag Igniter; Passenger Side (N200)
Address 16: Steering wheel Labels: 1J0-907-487-A.lbl
Part No: 1J0 907 487 A
Component: Lenkradelektronik 0005
Coding: 00118
Shop #: WSC 05311
VCID: 2F6C9298EDFEA53274-5140
No fault code found.
Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
Part No: 3B0 920 929 C
Component: KOMBI+WEGFAHRSP VDO V04
Coding: 13235
Shop #: WSC 06496
VCID: 275C7AB8C50EFD72BC-5124
WVWVE63B94E275110 VWZ7Z0D9140863
3 Faults Found:
01177 - Engine Control Unit
64-10 - Not Currently Testable - Intermittent
01315 - Transmission Control Module
49-00 - No Communications
01304 - Radio
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 05311
VCID: 70EE51E43040FACA2D-5124
2 Faults Found:
01304 - Radio
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 80 Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 05311
VCID: 377CAAF815AE6DF22C-4B00
Subsystem 1 - Part No: 1C1959801
Component: 80 Tõrsteuer.FS KLO 0202
Subsystem 2 - Part No: 1C1959802
Component: 80 Tõrsteuer.BF KLO 0202
Subsystem 3 - Part No: 1C0959811
Component: 80 Tõrsteuer.HL KLO 0202
Subsystem 4 - Part No: 1C0959812
Component: 80 Tõrsteuer.HR KLO 0202
1 Fault Found:
00912 - Window Regulator Switch; Front Left (E40)
27-10 - Implausible Signal - Intermittent
End-------------------------(Elapsed Time: 04:51)--------------------------
What do you guys think? Also, anybody have access to the b5.5 bhw wiring diagram? It would be nice to have an idea what the wires are for that I am having issues with
Thanks everybody for the comments and tips too!
