TedStriker
Hi Guys,
I have a 2005 Mk5 Golf TDI DSG with the 2.0 140HP BKD engine. It's on just over 150k miles and recently I've done a bit of work on it. To cut a long story short it's had a new flywheel (Genuine LUK) and replacement known good gearbox. I did all the work myself but am pretty confident everything was done up correctly and I used new TTY bolts for the flywheel, correctly torqued. Problem I'm having is a loud tinny rattle when shutting off the engine. To me it sounds like a failing flywheel and I'd be looking for a replacement were it not for the fact that I know the flywheel is brand new!
So my question - before I pull the thing apart again (not good outdoors in UK this time of year), is there anything else that could be causing it? The flywheel definitely needed replacing - the old one was completely seized, but I think I had this rattle before starting the job too. I was a little confused when I found the seized flywheel as I was expecting a loose rattly one bearing in mind the shutdown noise.
The car drives great, no clunks, bangs or rattles when driving and gear changes are silky smooth.
Any ideas?
Thanks,
Ted
Any ideas?
Thanks,
Ted
